How can I prove this function is a linear function?
  • Thread starter Thread starter tamtam402
    Function Linear
6 replies · 4K views · last reply
tamtam402
I'm trying to prove f(r) = A [itex]\bullet[/itex] (r - kz) is a linear operator, but I don't understand why it is linear.
A function of a vector is called linear if:
f(r1+r2) = f(r1) + f(r2) and f(ar) = af(r)
f(r1+r2) = A [itex]\bullet[/itex] (r1+r2 - kz) = A[itex]\bullet[/itex]r1 + A[itex]\bullet[/itex]r2 - A[itex]\bullet[/itex]kz
However, f(r1) + f(r2) = A[itex]\bullet[/itex]r1 - A[itex]\bullet[/itex]kz
So, I just proved that the function is NOT a linear function, how great... :(
By the way, r = (x,y,z) in this book, if that changes anything.
Is it safe to assume this is an error in my book's manual? I even tried developing the vectors, here's my attempt. (Disregard the 3.7.1 part)
Ok, upon further investigation, the only way this can be linear is if I have to apply the -kz part BEFORE writing down my r vectors, which means
f(r1+r2) = (a1,a2,a3) [itex]\bullet[/itex] (x1+x2,y1+y2,0)
If that was the case, how in the hell was I supposed to know I had to do that (as opposed to what I did in my scanned solution)??!
I'm assuming by you saying r is a vector, you're saying r[itex]\in[/itex]ℝn. Notice that what you're trying to prove is f is closed under addition and scalar multiplication which implies f is linear.
Suppose that : r1,r2[itex]\in[/itex]ℝn
Then the way you would go about proving something like f(r1+r2)=f(r1) + f(r2) is to literally ADD the two vectors together since adding two objects together from the same field should result in something from the same field ( If it doesn't then you simply don't have anything to prove here ) and THEN you perform the operator f on the NEW object. Simply separating the newly formed object into its two founding objects is a simple task at this point which should result in your answer.
k is the unit vector in the z direction, and r is given by:
r = x i + y j + z k
Therefore, f (r) = A [itex]\bullet[/itex] (x i + y j)
Alternately,
f(r1) = A[itex]\bullet[/itex] (r1 - k z1)
f(r2) = A[itex]\bullet[/itex] (r2 - k z2)
Try it now.
Note: [itex]z[/itex] is the third component of [itex]\textbf{r}[/itex], so if you have [itex]\textbf{r}_1[/itex] and [itex]\textbf{r}_2[/itex] you need [itex]z_1[/itex] and [itex]z_2[/itex].
RGV
Yeah thanks everyone. I was assuming the kz wasn't the "same z" as the z component from the r vectors, which means I considered r1-z as (x1,y1,z1)-(0,0,z) = (x1,y1,z1-z).
