How can I put this summation into a closed form?
  • Context: Undergrad
  • Thread starter Thread starter beadmaster
    Closed Form
6 replies · 4K views
beadmaster
Hi,
I can't think / remeber how to write the following expresion in a closed form,
the function is a summation of natural numbers between 1 and an upper limit "K", written as
Sigma x with limits K and 1 effectivly, straightforward etc...
what i want is the summation of all the "summations" between K and 1 so sigma (1,K) + sigma (1,(K-1)) + sigma (1,(K-2)) etc.. until it reaches sigma (1,1) ie 1.
its easy to visulise, take K as 5, the expression would be
5+4+3+2+1
+4+3+2+1
+3+2+1
+2+1
+1
which gives 35, i am wanting the answer in terms of K (im presuming its possible) or at least can be written much neater than an expansion, cheers (I thought it could possibly be written as a general sigma summation but prehaps with tending limits, but if so how do you represent the tending being discrete and not continous)
cheers,
tom
It is fairly well known that
[tex]\sum_{i=1}^n i= \frac{n(n+1)}{2}[/tex]
so your "sum of sums" is
[tex]\sum_{k=1}^n\left(\sum_{i=1}^k i\right)= \sum_{k=1}^n \frac{k(k+1)}{2}[/tex]
It is also (reasonably) well known that
[tex]\sum_{k=1}^n k^2= \frac{n(n+1)(2n+1)}{6}[/tex]
putting those together,
[tex]\sum_{k=1}^n \frac{k(k+1)}{2}= \frac{1}{2}\sum_{k=1}^n k^2+ \frac{1}{2}\sum_{k=1}^n k[/tex]
[tex]= \frac{1}{2}\left(\frac{n(n+1)(2n+1)}{6}+ \frac{n(n+1)}{2}\right)= \frac{1}{4}n(n+1)\left(\frac{2n+1}{3}+ \frac{3}{3}\right)= \frac{n(n+1)(n+2)}{6}[/tex]
You will note that for your example, with n= 5, this gives
[tex]\frac{5(6)(7)}{6}= (5)(7)= 35[/tex]
thats great thanks, i knew the general summations but tbh i wouldn't have the wit to make some of those connections, not currently at least...:P
cheers
That turns out be remarkably simple! I hadn't expected it to.
Actually, I was surprised that the final formula was so simple!
i recognise the final answer from somewhere else, o well thanks again
can i just mention that that "proof" or process appears increadibly elegant, how long did it take for you to do, could i be so intrusive to ask about you level of expertise as i am taken back by again by the elegence of the solution
cheers
