How Can I Solve This Complex Integral Using Trigonometry or Complex Analysis?
9 replies · 2K views
asi123
Hey guys.
I have this integral, I tried to use trigo, tried to use the complex expression but nothing worked, can I please have some help?
Thanks a lot.
The complex Residues method should work fine; why don't you show us what you tried for that method...
Ok, so I tried to use the residues theorem.
I did the substitute but ended up with that really ugly expression, should I use the residues theorem on it?
I won't be able to read your attempt until admin approves your attachment. You can save time by uploading your file to imageshack.us and posting a link to it instead.
http://img8.imageshack.us/img8/1059/scan0015p.jpg
Thanks a lot.
Okay, so far so good...now find the 4 roots of the denominator in order to find the poles...which of those poles lies within your contour?
To make your calculations easier, you should note that if [itex]|z^2|>1[/itex] then so is [itex]|z|[/itex]; and [itex]3+2\sqrt{2}>1[/itex].
Also note that [tex]\sqrt{3-2\sqrt{2}}=\sqrt{2}-1[/tex]
Oh, I've only now noticed your calculations tips :confused:
Anyway, this is what I did:
http://img27.imageshack.us/img27/4732/scan0016y.jpg
I've to warn you, The numbers are awful.
Does it seems right?
Thanks a lot.
They sure are! :biggrin:
Luckily, they're also correct:approve:...you can simplify them though...after a little algebra you should find that [itex]A=B=\frac{-1}{\sqrt{2}}[/itex] and so your final result becomes [itex]2\pi(\sqrt{2}-1)[/itex]
Thanks a lot :smile:
