Mentor
- 15,823
- 10,715
mfb said:
Classic!
mfb said:
I don't think this is necessarily true. Some software can have a very informal development history. You would need to be very loose with the terminology to make that statement about all software..Scott said:With any system there are "stakeholders" who determine the requirements and audit the testing - and in many cases, fund the development process.
Indeed. My experience has been that the formal process is the exception rather than the rule.FactChecker said:I don't think this is necessarily true. Some software can have a very informal development history. You would need to be very loose with the terminology to make that statement about all software.
But seems to be that open source allows for the users to sometimes find these errors before running the program or may be able to fix it. So it does solve somethings, but open source can then be more buggy depending on the support from the company right?stevendaryl said:I didn't claim that open source would solve everything.
\RaulTheUCSCSlug said:open source allows for the users to sometimes find these errors before running the program or may be able to fix it.
As others said, they can't. Open-source software will have bugs too, and even in-house custom software developed for a large collaboration (like in particle physics) will have bugs. You just have to assume that these bugs are rare, and knowing that the bugs possibly exist, be on the lookout for possible problems.fluidistic said:I wonder how can scientists trust closed source programs/softwares. How can they be sure there aren't bugs that return a wrong output every now and then?
This might be true in principle, but few users, if any, are going to spend the time doing an extensive code review before using open-source software. If you run into strange behavior by some software, then you might go look into the code to see if there's something wrong. This kind of transparency is one of the main advantages of open-source software.RaulTheUCSCSlug said:But seems to be that open source allows for the users to sometimes find these errors before running the program or may be able to fix it.
The original meaning of "hacking" was programming for the fun of programming. A Chech coworker of mine called it "happy engineering". And it is certainly possible for someone working out of their garage to create a useful product - as a solo effort.FactChecker said:I don't think this is necessarily true. Some software can have a very informal development history. You would need to be very loose with the terminology to make that statement about all software.
A lot of code is initially developed informally. As the code evolves, it becomes larger and more useful. Then somebody wants to use it in a serious way and either doesn't know or doesn't care that it hasn't been fully validated. Unless there is enough time and money to refactor the code, it is likely to be used without a formal development process..Scott said:The original meaning of "hacking" was programming for the fun of programming. A Chech coworker of mine called it "happy engineering". And it is certainly possible for someone working out of their garage to create a useful product - as a solo effort.
I should have been clear that I was referring to more serious efforts - such as the question about an election system that I was responding to.
In general, the more complex the system and people are involved, the more needs to be written down.
That would be an example of code that shouldn't be trusted - meaning, it shouldn't even be installed on a critical computer system. For example, most would consider Adobe Reader as non-critical software. What's the worse that could happen - it crashes and you can't read a document. But a few years ago it provided the entry point for a zero-day computer virus - a Trojan that used to install key-loggers and all sorts of other nasty things.FactChecker said:A lot of code is initially developed informally. As the code evolves, it becomes larger and more useful. Then somebody wants to use it in a serious way and either doesn't know or doesn't care that it hasn't been fully validated. Unless there is enough time and money to refactor the code, it is likely to be used without a formal development process.
.Scott said:That would be an example of code that shouldn't be trusted - meaning, it shouldn't even be installed on a critical computer system. For example, most would consider Adobe Reader as non-critical software.
The tests are repeated on every release. Actually, it tends to be even faster than than: every code commit. We use automated software to test the business logic of all of our software, unit tests to determine individual method accuracy, and we use external checkers to verify that not only the output was correct, but the algorithm used to make it.fluidistic said:I wonder how can scientists trust closed source programs/softwares.
How can they be sure there aren't bugs that return a wrong output every now and then? Assuming they use some kind of extensive tests that figures out whether the program behaves as it should, how can they be sure that the programs aren't going to suffer from bugs and stuff like that (malicious code included) in further releases?.
First, let's talk about "critical". I mentioned "mission critical" before - and perhaps I abbreviated it as simply "critical". Generally, "mission critical" refers to components that must perform correctly in order to successfully complete a mission. And by mission, we are talking about thinks like allowing the LHC to work, allowing an Aircraft Carrier to navigate, allowing a Martian lander to explore (or allowing the Mars Climate Orbiter to orbit). Even if lives are not at stake (which they may), they involve major portions of hundreds of careers - or more.anorlunda said:What about the scientific calculator on the scientists desk; would you consider that critical? A wrong calculation could mislead the scientist.
Would you extend validation requirements down to the level of devices costing only a few dollars or a few pennies each, or would you trust certain manufacturers based only on their size and reputation?
Or perhaps you mean that trivial devices can't be critical?
To be fair, systems like that do exist, and http://www.linux.com/news/enterprise/high-performance/147-high-performance/666669-94-percent-of-the-worlds-top-500-supercomputers-run-linux-/ to answer your question, on a massive scale, a lot of research is done on Opensource systems. However, to answer your question about trusting proprietary software, the math and physics required to do code these research (simulation) software is extremely complex and those coders are paid a ton to make sure it works right when you plug numbers into it. You still have to know what you are punching in though. Source: A solar physicist at my University.fluidistic said:I wonder how can scientists trust closed source programs/softwares.
How can they be sure there aren't bugs that return a wrong output every now and then? Assuming they use some kind of extensive tests that figures out whether the program behaves as it should, how can they be sure that the programs aren't going to suffer from bugs and stuff like that (malicious code included) in further releases? Are there any kind of extensive tests performed on software that are generally used in branches of physics or any other science involving data analysis? Blindly trusting a closed source program seems to go against scientific mindset to me.
.Scott said:First, let's talk about "critical". I mentioned "mission critical" before - and perhaps I abbreviated it as simply "critical". Generally, "mission critical" refers to components that must perform correctly in order to successfully complete a mission. And by mission, we are talking about thinks like allowing the LHC to work, allowing an Aircraft Carrier to navigate, allowing a Martian lander to explore (or allowing the Mars Climate Orbiter to orbit). Even if lives are not at stake (which they may), they involve major portions of hundreds of careers - or more.
I'm not sure where I pretended that the mundane and trivial carried no risk. Perhaps you didn't catch my allusion to the mundane and trivial that costed a very significant Mars mission - or my mention of the Adobe zero-day issue.anorlunda said:A lowly chip in a single security badge could enable a saboteur to bring all that crashing down. The cliché is "The bigger they are, the harder they fall."
I think you're being pretentious in dismissing my point that software is all around us, in the mundane and trivial, as well as in the grand and elaborate. It is extreme and foolish to pretend that the mundane and trivial carry no risk to the mission.
Actually, I think most people have no opinion on the matter. On the other hand, I have worked with SCADA systems and was not completely satisfied with how well they were protected. And I think the Iranians were not fully satisfied with how well their Uranium refinery SCADA system was protected.anorlunda said:At the other extreme. I'm currently working on an article about power grid cyber security. On that subject, the public and the politicians believe that every mundane digital device owned by a power company could be hacked to bring the end of civilization.
Hi rootone:rootone said:Even those get ironed eventually by 'defensive' programming adjustments which detect and report improper input and so on before the program will proceed.
harborsparrow said:almost all software on the planet does unexpected things once in a while.
