How can the Higgs boson have mass?
The Higgs boson has been experimentally confirmed to have a mass of 125 GeV, as discovered at the Large Hadron Collider (LHC). The confusion arises from the misconception that the Higgs boson itself gives mass to other particles; in reality, it is the vacuum expectation value of the Higgs field that provides mass. This non-zero value in the lowest energy state of the Higgs field is crucial for understanding how particles acquire mass. The Higgs boson is a manifestation of disturbances in the Higgs field, not a source of mass itself.
  • Understanding of the Standard Model of particle physics
  • Familiarity with the concept of vacuum expectation value
  • Knowledge of field theory and particle interactions
  • Basic grasp of quantum mechanics principles
  • Study the Standard Model of particle physics in detail
  • Learn about vacuum expectation values and their significance in quantum field theory
  • Explore the role of the Higgs field in mass generation
  • Investigate the implications of Higgs boson discovery on modern physics
Physicists, students of particle physics, and anyone interested in the fundamental mechanisms of mass generation in the universe.
Natskyge
So this may be just me being stupid.
Anyway, so i was reading about the higgs and i read it has been found in LHC to have a mass of 125 Gev, according to their expriments. Now here comes what i don't understand, how can the particle that gives mass have mass, and wouldn't that cause the higgs field to collaps in on it self due to its own mass?
Thanks in advance!
As you can imagine, this is a very technical issue and it is very difficult to make good analogies at B level. Questions such as "how can A give B?" are by nature going to be best answered on a rechnical level, but you would first need to understand the framework and how it predicts things to work. Only then can you adequately get your question answered.
That being said, you are likely to have some sort of mental image of the process. In order to address that, you would have to be more specific on why you would not expect the Higgs to give mass to itself.
Also, in the end, it is not the Higgs boson which gives mass to other particles, it is the vacuum expectation value of the Higgs field which does. Making an analogy to a pond, the vacuum expectation value is the depth and the particles are ripples on the surface.
Well i have read some books on the matter.
It just confused me how the higgs can have mass, which it gets from it self. My thinking is that would make it gain more and more mass and eventualy clump together, like normal matter.
This is simply not how the subatomic world works. You cannot think of Higgs particles as little balls sticking to things and thereby giving them mass. And again, it is not the Higgs particle which gives mass to other particles, it is the vacuum expectation value.
Ah okay, sorry.
Looks like i have some reading to do.
So the higgs particle is not what gives mass, just a particle that appears when you disturb the higgs field? Like virtual particles?
No, like normal particles. All particles are essentially disturbances in their respective fields. What sets the Higgs field apart is that it can have a non-zero value in its lowest energy state. It is this non-zero value which results in giving mass to particles.
Ah okay, thanks!
