How can we determine viscosity from a graph using Poiseuille's equation?
  • Thread starter Thread starter jsmith613
    Graph Viscosity
To determine viscosity using Poiseuille's equation, one must plot the height of a water tank against the rate of flow. The gradient of this graph does not directly provide viscosity; instead, it is necessary to rearrange the equation to isolate viscosity (η). The correct formula derived from the equation is η = (πρr^4)/(8l * gradient), where ρ is the fluid density, r is the radius of the pipe, and l is the length of the pipe. This approach allows for the calculation of viscosity based on the slope of the plotted graph.
  • Understanding of Poiseuille's equation
  • Knowledge of fluid dynamics principles
  • Familiarity with graphing techniques
  • Basic algebra for rearranging equations
  • Study the derivation and application of Poiseuille's equation in fluid mechanics
  • Learn about the factors affecting viscosity in different fluids
  • Explore graphing techniques for analyzing fluid flow data
  • Investigate experimental methods for measuring viscosity
Students and professionals in physics, engineering, and fluid dynamics who are interested in understanding the relationship between flow rate and viscosity using Poiseuille's equation.
jsmith613
if we use Poiseuille's equation, plotting the varying height of a water tank againts the rate of flow, does the gradient of the graph tell us the viscosity, or do we re-arrange the equation to find viscoisty.
Thanks
Thanks
Gradient = (πρr^4)/8ηl
Re-arranging this gives: η= (πρr^4)/(8l ∗gradient)
BUT if y = mx + c
y = η
and x = (πρr^4)
So how do we use Poiseullie's equation to find viscosity, when we plot height of tank against (x axis) rate of flow (y)
thanks
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 16 ·
