How can we see the ISS at 200 miles away with the naked eye?
  • Context: Stargazing
  • Thread starter Thread starter TruthSeeker777
    Eye Iss
The discussion revolves around the visibility of the International Space Station (ISS) from Earth, particularly how it can be seen at a distance of 200 miles with the naked eye. Participants explore the implications of angular resolution, light reflection, and contrast against the sky, with references to other objects like airplanes and signal mirrors.
  • Some participants question how the ISS can be seen at 200 miles when planes, which fly at around 10 miles, are not visible due to angular resolution limits of the human eye.
  • Others argue that the ISS reflects sunlight, making it visible, especially during daylight, and that human eyes are sensitive to a wide range of brightness.
  • A participant highlights that the ISS appears as a bright dot due to its high contrast against the sky, rather than being limited by angular resolution.
  • There is a discussion about the angular resolution of the eye, with some participants providing calculations and comparisons to commercial airliners.
  • Some participants mention the reflectivity of the ISS's solar panels and question how much light they reflect compared to other surfaces.
  • References to other visible phenomena, such as Iridium flares and the visibility of stars from space, are made to illustrate points about light reflection and visibility.
  • There is a debate about the nature of the surfaces of the ISS and signal mirrors, with conflicting views on whether they are flat or convex.
Participants express differing views on the visibility of the ISS and the factors contributing to it, particularly regarding angular resolution, contrast, and the nature of reflective surfaces. There is no consensus on the exact mechanisms or conditions that allow for the ISS to be seen from such a distance.
Some discussions involve assumptions about visibility conditions, such as atmospheric effects and the specific characteristics of reflective surfaces. The conversation also touches on the limitations of human perception and the variability in visibility based on environmental factors.
TruthSeeker777
TL;DR
how can we see the ISS at 200 miles away?
NASA says the ISS is 200 miles away.
Planes fly at around 10 miles from the surface and we can't see them due limits to the angular resolution of the human eye.
Given the inverse square law of light and the ISS being 20 times the distance to the plane, how is it possible to see the ISS?
Astronomy news on Phys.org
Not during daylight.
ISS reflects light from the sun, like the moon.
...and our eyes are shockingly sensitive. It's tough to tell because they adjust automatically, they have a very wide range of brightness we can see.
Consider how the moon during the day (the illuminated part) looks dim, but at night appears almost blindingly bright even though it hasn't actually changed.
Do you mean commercial airliners? What makes you think they can't be seen due to resolution limits?
And if they can't be seen, it is generally a contrast issue against the sky, or a resolution issue.
The angular resolution of the eye which is 0.02° and corresponds to 0.3 m at a 1 km distance. If the plane has a wingspan of 15 m then the average person should just be able to see it at 45 km. You will just about see it as dot rather than anything that looks like a plane. This is assuming very clear sky conditions.
I can't see how the eye can see the ISS which is at 20 times distance at all.
Your eye cannot see anything that is beyond the limits of its angular resolution. Either the object must be bigger or closer.
The angular resolution of any star (other than the sun) is much smaller than the resolution limit of the eye.
Here's an example even more dramatic than the ISS. A hand held signal mirror. The video shows it seen from 0.7, 11.1 and 43 miles away.
For a typical commercial airliner, it's closer to 35m, and up to as much as 80m.
Right. So you can see it. Nobody said anything about making it out to be more than a dot.
The ISS is naked eye visible only as a dot.Now that the premise of your confusion (the comparison to aircraft) has been dealt with, let's move on to the meat of it.
The ISS is seen because of its extremely high contrast, not because of its angular resolution. It is seen by direct unfiltered starlight reflecting off its very flat solar panels, so it's very bright. Far brighter than any aircraft.
And as FactChecker has pointed out, distant stars are easily visible despite being no more than points in our vision.
The crux of the issue is brightness of source against background.
Thanks, that is only because its a convex mirror.
Check your facts. It looks pretty flat to me.
Thanks, that is only because its a convex mirror. Light spreads out when its reflects off a convext mirror. If the mirror was flat you wouldn't be able to see it beyond the angular resoolution limits? Pictures of the ISS don't seem to indicates concave surfaces from what I can see?
All my signal mirrors are flat. Any curve at all to them would defeat their operation. What is the basis for you claim that the video shows a convex signal mirror? Please cite your source on that.
Also, so far in this thread, you do not seem true to your username...
It is not convex. It is flat.
A convex mirror would not appear as a single point of light over the large range of distances from 0.7 miles to 43 miles.
ah yes, you're right its not convex. Thanks.
But the lack of convexity is one of the hallmarks of much of stealth design (look at the SR71!) . A flat surface will reflect a point source only over a very small range of angles. It makes it impossible to track. This is also why you must actively wobble the signal mirror.
The other suppositions about visibility from @TruthSeeker777 are incorrect as noted.
CORRECTION - its not a convex mirror.
This is a good point. A mirror certainly reflects the vast majority of light from it. Is the suggestion that solar panels from the ISS are reflecting the vast majority of light that hits it from the sun? The solar panels I've seen do not seem to be very reflective and are grey in colour.
According to Google (which is cheating here):
"Those solar panels convert 30% of the sunlight into electricity, and another part into heat. The amount of light reflected is only about 20% (less than the reflection coefficient of e.g. grass)"
The reflectivity of the Moon is 0.12 - about that of blacktop asphalt.
The point being that, in contrast to the blackness of space - especially when your eyes are attuned to it - sunlit blacktop asphalt is very bright.
FactChecker said:
I really do not know how much the visibility of bright pin-point of light depends on some diffusing in the atmosphere to make a larger. Are the stars visible to astronauts in space?
UPDATE: Apparantly, stars are visible to astronauts in space. https://phys.org/news/2017-08-astronauts-stars-space-station.html
This is a very good point. I have certainly seen pictures of astranauts & ISS where the sky behind them is pitch black and no stars are visible.
Yes the stars are visible to astronauts in space. This was one of the loony items brought up by the Apollo deniers. Why would they not be??
The mirror can be flat because the Sun is over half a degree in diameter, which is greater than the angular resolution of your eye. With RADAR, the illumination angle is very much less.
"Those solar panels convert 30% of the sunlight into electricity, and another part into heat. The amount of light reflected is only about 20% (less than the reflection coefficient of e.g. grass)"The reflectivity of the Moon is 0.12 - about that of blacktop asphalt.
Certainly but the moon is far far bigger than the ISS. If I use a flashlight on an object that is smaller than the angular reolution would allow for in the dark should I be able to see it?
There are two factors at play here:
1. Inverse square law - i.e an object's brightness (measured in Lumens) dereases by 1/4th every time you double the distance to it
2. Angular resolution of the human eye
Yes of course. But you still have to wobble your rescue mirror!
Why? Scratch a hole in the mirror, so you can look through at your outstretched arm thumb. Point your thumb at the target, then reflect the Sun onto your thumb. Problem solved.
So when the rescue plane flies over Is your thumb sight good to half a degree? Also you want the Flashy Wobble for contrast. I'll use the wobbly eyeball approach, thanks!. Actually I would do both...
It works well. Measure the size of your thumbnail against the Moon or the Sun. A steady, bright light is easier to see from a moving aircraft than momentary flashes. I try not to need it.
Note again that the dynamic range of our eyes is very wide. A camera taking a photo of a brightly lit astronaut won't capture the dim stars.
The point is simply that this:
is a poor yardstick.
I think we've established that the visibility of stars pretty much resolve any doubt.
  • · Replies 22 ·
27K
16K
