How can you find two different values for sin^-1(0.750)?
  • Thread starter Thread starter ND3G
6 replies · 15K views
ND3G
I am working on a statics question and one of the angles is sin^-1(0.750) which I calculate as 48.6 degrees though the book gives 131.41 degrees
If I calculate sin(48.6) it equals 0.750
If I calculate sin(131.41) it equals 0.750
Clearly there is some relation or rule that I am unaware of. How do I ensure that I find the proper angle?
Just draw the unit circle and joggle a bit then all becomes clear.
sin^1(0.75) means "what angle gives y = 0.75" if you do the unit circle. You'll see that there is two angles in the range 0 - 360 degree that gives you that value.
Which is correct depends on what the problem is, what physical situation it is and so on.
Ok, I figured it out. Because of the direction of the vector it is not 0 degrees + 48.6 degrees but 180 degrees - 48.6 degrees which equals 131.4 degrees
Your calculator cannot help you with interpreting the output in relation with the problem you are working on. The inverse trig functions on a calculator will only give output in the ranges
arcsin or arctan: -90º to +90º (not quite 90º, of course, for arctan)
arccos: 0º to 180º .
In order to define these as functions, it is necessary to have restricted ranges on
y=f(x) and the calculator is programmed to follow these definitions (this is why the inverse trig functions are sometimes identified as Sin^{-1}, Cos^{-1}, etc., rather than using lower-case).
As you note that the positive sine value is associated with two angles (in the first and second quadrants), it is important to have a picture in mind for the physical situation in order to decide which angle is appropriate to the solution. (I particularly warn engineering students about this all the time: you have to know what the result should look like because the calculator can't.)
