How Can You Shave Without Cutting Yourself?
  • Thread starter tgt
    Cutting
43 replies · 10K views · last reply
tgt
Two questions:
1. How to shave? cream on shaver then shave or cream on face then shave?
2. I just cut my lip and blood comes out easily. What do I do?
1. foam on face.
2. put a piece on tissue on it.
wolram said:
1. foam on face.
Let's avoid infection.
1. foam on face
2. rubbing alcohol on cut
3. stifle scream
4. put a piece of tissue on it.
tgt said:
Two questions:
I take it you're young and just learning? Do you have an older man you can ask to show you? If you don't have a father around, perhaps an uncle, older cousin, best friend's father...
Just be lucky you don't have to shave your armpits. Getting a nick under there...OUCH :bugeye: !
I've never managed to nick my armpits. I only get myself along the wrinkly skin on the back of the ankle when I'm rushing. Faces seem a bit trickier though...or maybe guys are just wimpier :biggrin:.
tgt said:
Two questions:
one word:
Norelco
There is some tricky skin on the neck under the jaw and some other places that are ready-made for nicks.
Nah, we just bleed all over everything in bathroom.
Styptic pencil.
Stings.
Stops the bleeding.
Make sure you always have a sharp blade, a dull blade will usually cause more cuts, but a new blade will too since you just used a dull one and were pressing too hard.
The rule is to always shave in the direction that the hair is growing. That doesn't work for me. On the underside of my chin, I have to shave forward against the grain. What's driving me nuts now is that W bought me a disposable (but she doesn't know it's disposable) electric razor for Xmas. I therefore have to 'shave' with this thing, which is as useless as tits on a nun. When she's out of town, as currently, I sneak out the good old Schick and foam up.
I had a reply for that, but it's probably too disgusting to actually write out.
You could always grow a beard. :biggrin:
whisper it then
Don't be shy, Moonie. Spill, already...
Do people recommend an electric shaver as a man will need to shave for the rest of his life, if he doesn't like facial hair?
So why would someone stick with cream and blade for a long period of time, if cost isn't an issue for him.
tgt said:
what is that?
An electric shaver.
tgt said:
what is that?
Its a triple head electric shaver.
Dang, Evo beat me to it. But as I recall, Santa uses a electric shaver, I guess when his sled is in the shop.
Are you using those cheapo BICs?
My Gillette Fusion hasn't really failed me (I only grow a goatee, but far from thick) and it's hard to get a cut as long as you have some sort of foam/gel since the blade bends (unlike the cheap BICs).
You can get an electric one if you tend to grow thick hair (something I fortunately don't have to experience).
That commercial signals the beginning of the Christmas season for me. I am glad that they have kept that going for so many years. Noelco.
Those BICs, exactly.
ROFL.
Ah, a blade is a blade. I used the Schick whatever, with the whisker ejector function, which suited me very well... until they stopped selling refills for them. Then I switched to the Gillette system, because it was the only one that worked. (Incidentally, I have no problem with the Bics other than them clogging up too quickly. They're good blades.)
Heh, they're just more forgiving to the ones who aren't good at pivoting the wrist around bends.
The heads will angle for you so you don't accidently dig into the skin (which is why some get cut).
wolram said:
ROFL.
I think that the problem here is that she doesn't really want to display that heart-shaped patch... :rolleyes:
I have to use the disposable single blade Bumpfighter razors since my skin is so sensitive. If I use anything else, even when going with the grain, I break out like I am 12 all over again. The added bonus is that they're VERY cheap and they don't cut the hair too low... which can potentially cause ingrown hairs.
It's disposable! You're missing your escape route here. Tell her "oh it's disposable", throw it away, and be done with this madness!
Hammer them down and bite them off from the inside.
-Or-
1. Toss that rusty single blade Bic you've been using since 2006, Use a fresh sharp razor. The current generation of razors have at least a dozen blades and are longer than they are wide.
2. Slowly scrape the vorpal razor across the tender, nick prone skin of your face (etc.) in rapid strokes.
3. Use long strokes for the flat areas, longer ones for the nooks and crannies.
4. A registered nurse should be on call during this dangerous phase of your short life.
5. Keep the door closed. No one wants to hear a grown man cry.
6. Apply aftershave. I know it stinks, but according to something I saw on TV, the chicks really dig it. Also, the alcohol will help with the infection.
7. FInally, apply lots of shave cream. It's there so you can cover the nicks, scrapes, potholes and missed areas, so use it.
I use scissors! ... but just to trim my beard.
When I used to shave, at one point I switched to something called "Edge ProGel" for shaving cream. It works so-o-o-o much better than the cheap Barbasol stuff I'd been using, but probably most anything else does too.
