How Can You Transfer Data Between Modules in Comsol?
  • Thread starter Thread starter aecetin2000
    Comsol Data
Transferring data between modules in COMSOL can be achieved through coupled application modes or by exporting and importing data. The discussion highlights the need to run simulations in the electrostatic toolbox first, followed by loading the generated field data into the in-plane wave model. Utilizing application mode variables for initial conditions or solver specifications is recommended for a seamless integration of results.
  • Familiarity with COMSOL Multiphysics software
  • Understanding of the electrostatic toolbox in COMSOL
  • Knowledge of in-plane wave modeling techniques
  • Experience with data export and import processes in COMSOL
  • Research how to implement coupled application modes in COMSOL
  • Learn about defining initial conditions using application mode variables
  • Explore the data export and import functionalities in COMSOL
  • Investigate interpolation methods for field data transfer between modules
Engineers and researchers working with COMSOL Multiphysics, particularly those involved in electrostatics and wave modeling, will benefit from this discussion.
aecetin2000
Comsol data transfer (urgent)
I am trying to model a system which should simulate in two modules in Comsol. First I have to run the problen in electrostatic toolbox and then load the field data generated in this model to the in-plane wave model and run it in this model. Is anybody know how to do this interpolation?
Might be easiest to do it "coupled", i.e. solve both application modes in same model and use results extracted from other some way in the other (either use the application mode variables in defining values, like initial values for example, of the other in the other; or extract an initial condition (solver specs) from the other application mode). Sure, you can do some export -- import of data as well (under the file menu), but might be simpler to do it without.
Thank you for your help. That helped me a lot.
