How close can two protons get if....
The discussion revolves around the question of how close two protons can approach each other, given one is at rest and the other has kinetic energy corresponding to a temperature of 107 K. The original poster references a specific answer from their astronomy textbook.
  • Participants discuss the kinetic energy of the proton at rest, with some asserting it is zero. There is debate over the implications of kinetic energy conversion to potential energy at the moment of closest approach. Questions arise regarding the completeness of the problem statement and the appropriateness of the equations being used.
Participants are exploring various interpretations of the problem, particularly concerning the motion of the proton at rest and the validity of the equations proposed. Some guidance has been offered regarding the conservation of momentum and the nature of potential energy, but no consensus has been reached.
There is uncertainty about whether the "at rest" proton is fixed in place or can move. Additionally, participants note discrepancies in units and the appropriateness of mixing different energy concepts in their calculations.
PAK108
Mentor note: Thread got moved to the homework section
How close can two protons get if one is at rest and the other has a kinetic energy equal to the average energy at T =107 K?
I know that the kinetic energy of the moving proton is 3/2kT, but what is the kinetic energy of the proton
at rest? This question is from my book in astronomy. The answer are supposed to be r= r = 1.1 × 10−12m
Any help appreciated
at rest?
Zero. What else?
At the moment of closest approach, both protons will move and have non-zero kinetic energy.
Is this homework?
at rest?
In your opinion what should be kinetic energy of a body which is not in motion?
the other protons kinetic energy is given so by virtue of its energy it can approach the other proton -in spite of repulsion from it so you must calculate the net work done by it in getting closer...
mfb said:
Zero. What else?
Is this homework?
Aha, I think I understand now, that means that all the kinetic energy becomes potential energy when the electron
are at the closest approach...thank you :)
Yes, this is homework (I realized that this should be posted at the homework section after posting. I am sorry for posting here)
No it does not.
For that to occur, both would have to stop at the same time, which violates momentum conservation.
I moved the thread to the homework section.
It's not clear from the problem statement that the "at rest" proton is meant to be able to move, or if it is to remain at rest (fixed in place). Is the problem statement complete and exactly as it was given?
Yes this is the complete problem statement
I tried to solve the problem like this:
3/2kT + mc2=k(e2/r2), solving for r gave r=1.2*10-9, which is like 1000 order bigger than the correct answer :(
That does not even have matching units, and I don't understand where you got that equation from.
PAK108 said:
mc2
what this energy term ( equivalent to mass) is doing there -is the problem talks about velocities comparable to velocity of light
The equation was just put together from the equation for "thermal energy and rest energy" = "potential energy"
the k's on the left hand side is not the same on the right hand side
LHS k=1,38065*10-23 J/K
RHS k=8,99*109 Nm2/C2
No, the problem does not talk about velocities comparable to light...basically I was just trying something since the units matched...the chapter mentions the rest energy of a proton (E=mc2) so I just gave it a shot
Why should that be true? Do you annihilate a particle to extract its rest energy? Even if that would be true, why one and not both?
That is clear and no problem. The potential energy still does not follow a 1/r2 law.
well you can not do these things as physics theory does not mixes Newtonian and sTR -it will be a mess.
Ah of course, it is supposed to be 1/r, that means that the calculations are completely off
  • · Replies 54 ·
12K
