sr241
- 83
if linear and angular momentum are separately conserved how dampening works? like in a suspension of a car
This discussion clarifies the relationship between damping forces and the conservation of linear and angular momentum. It establishes that while damping forces do not affect the total momentum of a closed system, they can convert mechanical energy into heat, thus affecting energy conservation. The conversation highlights that linear and angular momentum are separately conserved in a closed system, and emphasizes the distinction between damped and elastic collisions. The role of external forces, such as those from the ground or walls, is crucial in determining whether momentum is conserved.
PREREQUISITESPhysics students, mechanical engineers, and anyone interested in the dynamics of oscillating systems and the principles of momentum conservation.
You need to include the Earth as part of this closed system. The total linear and angular momentum of the Earth and car are conserved. The suspension of a car is composed of two main components, the springs which allow the tires to move with respect to the car, and the shocks which damp that movement so it doesn't oscillate.sr241 said:if linear and angular momentum are separately conserved how dampening works? like in a suspension of a car
rcgldr said:The total linear and angular momentum of the Earth and car are conserved.
In a closed system (no external forces) linear and angular momentum are separately conserved. Energy may be converted between potential (chemical, electrical, gravitational), angular, and linear energies, but the total energy is conserved (ignoring losses to heat that escape the closed system).sr241 said:Is it total of angular and linear momentum ...
Damping doesn't affect the total momentum. The purpose of damping is to reduce or prevent oscillations. During this process, damping may convert mechanical energy into heat, reducing the overall energy due to heat escaping the system.How damping force affect linear momentum and its conservation?
sr241 said:Is it total of angular and linear momentum is conserved or is the linear and angular momentum is separately conserved.
vlado_skopsko said:So in other words the momentum goes from macro to micro level but stays unchanged, if you watch the car dumpers and the atmosphere as a closed system.
Or maybe its better to say, the momentum goes from organized motion of particles to unorganized.
sr241 said:Consider the scenario one ball is placed between two movable walls; movable walls are connected so that there is no relative movement between these walls. Ball hits wall with a velocity = 10. trajectory of ball passes through center of mass of both walls and is normal to both walls. collision between first wall is damped but collision between ball and other wall is perfectly elastic. Then, will the linear momentum will be conserved? What would be the position of center of mass of both ball and wall ( after both ball and wall stops or do they stop moving?) relative to their initial position(I mean center of mass of both ball and wall combined)
sr241 said:… two balls of equal mass (say 1) is placed between two immovable walls. ball 'a' hits ball 'b' with a velocity = 10. trajectory of ball 'a' passes through center of mass of both balls and is normal to both walls.
collision between two balls is damped (due to deformation) but collision between balls and both walls are perfectly elastic …
will the linear momentum will be conserved. what would be the position of center of mass of both balls( after both balls stop) relative to their initial position(I mean center of mass of both ball combined)
tiny-tim said:hi sr241!no, the two collisions are as elastic (or damped) as each other.
tiny-tim said:in both cases, the total momentum (of the two balls) is zero, both before and after
tiny-tim said:internal forces do not alter the total momentum (including mutual forces between two bodies in the same system, such as the two balls)
There's a problem with that video, noticable at the very start. After the first collisions with the green walls, the bottom U shaped object is moving faster than the top object. If you pause the video just before the ball hits the left wall on the bottom object you can see it's moved further ahead, which it shouldn't have if those objects were supposed to be identical except for the red wall on the upper object.sr241 said:
In the video collision with red wall is damped and collision with all the green walls is perfectly elastic.
rcgldr said:There's a problem with that video, noticable at the very start. After the first collisions with the green walls, the bottom U shaped object is moving faster than the top object. If you pause the video just before the ball hits the left wall on the bottom object you can see it's moved further ahead, which it shouldn't have if those objects were supposed to be identical except for the red wall on the upper object.
sr241 said:
in the video collision with red wall is damped and collision with all the green walls is perfectly elastic. total mass of front and back walls is equal to double the mass of ball.
you can see in the first case linear momentum is not conserved, that means damping can affect conservation of linear momentum, right?
sr241 said:can damping be assumed as the force that affect conservation of linear momentum
