Can You Explain the Mystery of 9.8m/s^2 Acceleration on Earth?
  • Context: Undergrad
  • Thread starter Thread starter Theonefrom1994
The acceleration due to gravity on Earth is consistently measured at 9.8 m/s², a value established through historical experiments and observations, notably by Galileo in 1638. Despite the presence of air resistance, experiments such as pendulum oscillations demonstrate that the effect is negligible for small dense objects. Modern methods allow for accurate measurements of gravitational acceleration without a vacuum by analyzing the period of pendulums and plotting the results against their lengths. This approach confirms that air resistance does not significantly alter the calculated value of g.
  • Understanding of basic physics concepts, particularly gravity and acceleration.
  • Familiarity with pendulum mechanics and oscillation periods.
  • Knowledge of experimental data analysis and linear regression.
  • Basic understanding of air resistance and its effects on falling objects.
  • Conduct experiments using a pendulum to measure gravitational acceleration.
  • Explore the principles of Galileo's experiments on falling bodies.
  • Learn about the effects of air resistance on different materials and shapes.
  • Investigate the mathematical relationship between pendulum length and oscillation period.
Students of physics, educators conducting experiments in mechanics, and anyone interested in the historical context and experimental verification of gravitational acceleration.
Theonefrom1994
TL;DR
How did people find 9.8m/s^2 If there’s air resistance on earth ?
My understanding is that all falling objects on Earth will fall at the same acceleration of 9.8m/s^2 in the absence of air resistance . But isn’t air resistance everywhere on the planet since we have an atmosphere ? . So how did these scientists from back in the day figure out the 9.8 number ?
Theonefrom1994 said:
Summary:: How did people find 9.8m/s^2 If there’s air resistance on Earth ?
Someone has written a book about it:
https://www.springer.com/gp/book/9783319749587
It's a good question. However, there are many circumstances where air resistance only creates small errors. For example, dropping small dense objects, like an iron ball.
I like PeroK's answer. However, the question assumes, as Perry Mason would say "facts not in evidence". Galileo's suggestion that bodies accelerate at the same rate was proposed in 1638 and the vacuum pump was invented in 1650.
Furthermore, one can do this measurement today without a vacuum. Take a pendulum with bobs of fixed size and shape, but of different materials. Plot g vs 1/m and extrapolate to zero.
I was trying to know how people figured it out because it was never presented to me . I’ was sure there evidence for it I was just unaware Of what that evidence is And how it can be demonstrated if you don’t have a vacuum .
Suppose we have a pendulum and we count the time for a large number of oscillations. If air resistance is significant then by doubling the density of the bob (with the same size and shape) we should get a significant change in the time for the heavier bob - significantly less. If, however, we get almost the same time for both bobs, then air resistance must be almost negligible. Hence the time must be close to what we would get in a vacuum, and we can get an accurate estimate for ##g##.
Your question shows that you were actually thinking about the problem. Much of the Science we are taught at elementary level is not suitable for too much follow-up thinking. :smile:
Keep reading and asking.
Do this in air then. For small oscillation, the affect of air is negligible, y'know, the effect is so small it is in the high decimal digits.
We do this in many General Physics lab. Measure the period T of a pendulum at a particular length L. Then vary L, measure T again... You will have a series of values of T for each L.
Now plot T versus √L. You will find that it resembles a straight line. Do a linear fit through the data points. The slope of your graph is equal to 2π/(√g). This means that knowing the slope of your fitted line, you now can experimentally find g!
I've just done my students' next week's lab!
Zz.
Thanks for the responses ! This was helpful ! I’ll try to do my own set up with a pendulum and try this out !
Physical constants are often defined in one way, but best measured in a different way.
  • · Replies 18 ·
  • · Replies 41 ·
  • · Replies 28 ·
