How do different types of energy interact with space?
  • Level: Undergrad
  • Thread starter Nano-Passion
    Energy
33 replies · 9K views · last reply
Nano-Passion
Post edited 12/29/10.
From the scientific point of view not philosophical.. Do we really understand what energy is else than a simplistic definition of its existence?
We know that there are different types of energy such as:
Heat
Kinetic
Chemical
Nuclear
Mass
Electrical Energy
Radiant
Gravitational
How does energy interact with space? I don't really understand it.
Einstein says that gravitational energy interacts with space by bending it. What about all of the other types of energies? What is really going on under our eyes? I don't believe we understand it all, in fact, it would be very foolish to say so.
For example how does electrical energy interact with space? What about heat?
From what I know, heat can make atoms jiggle more out of their molecular position for instance.
So does this mean heat excites the fabric of space in some way?
russ_watters said:
KE=1/2 mV^2
PE=mgh
Definition: energy is the capacity to do work.
work=force*distance
Nothing vague about any of that.
What I am not looking for is the definition of energy, but what it really is.
Energy changes forms (see conversation of energy), it can be gravitational or electrical.
For example, in electrical energy we say that positive and negative ions attracts. But what is the underlying mechanism going on?
I don't want to know the textbook definition of energy, but what it TRULY is.
Surely it is not a simple question, we don't understand the concept as much as we think that we do.
Nano-Passion said:
What I am not looking for is the definition of energy, but what it really is... I don't want to know the textbook definition of energy, but what it TRULY is.
That's a self-contradiction: the definition (both in words and in math) is what it is. That's the entire point of a definition!
Yes.
Electromagnetic energy comes from moving charge with a certain voltage. It is very similar to mechanical work.
No, it is a simple question, you just don't like the answer! You want it to be more complicated than it really is.
Have you read the wiki on energy yet?
True, probably because I feel we do not truly understand it! I partly believe that if we truly understand it we would be much closer to a unified theory of Quantum Gravity or generally much more knowledgeable in physics. We don't understand many things, so sometimes we will say it just is!
But I am very limited in knowledge, so I might be speaking complete nonsense.
Thanks for your reply. ^.^^
Some claim that energy and frequency of a quanta are the same thing, in different units.
E = hf.
ref. Collective Electrodynamics, Quantum Foundations of Electromagnetism, Carver A. Mead
Planck's constant h and its radian equivalent h_bar = h/2pi are necessary for merely historical reasons--when our standard units were defined, it was not yet known that energy and frequency [were] the same quantity.​
We know almost all there is to be known about energy from the previous definition.You think there has to be more to it. It's up to you to point to us what you think that thing might be.
Perhaps the question "What really IS energy" is too broad.
Let me ask this: How does energy interact with space? I don't really understand it.
Einstein says that gravitational energy interacts with space by bending it. What about all of the other types of energies? What is really going on under our eyes? I don't believe we understand it all, in fact, it would be very foolish to say so. And that was the statement I was trying to make russ watters.
Yes, you are. Let's try it another way. This is a dramatization and not exactly how the history went:
If you push an object with 9.8 N of force for 1 meter, that's 9.8 N-m. A very long time ago, someone realized that this was a useful calculation to make and gave the result a name: "work"
Someone else figured out that if that object isn't constrained by friction it will accelerate and you can use the final velocity to calculate how much work was expended to bring it up to that speed. This is useful, so the result of that calculation was given a name: "vis viva".
If you lift a 1kg object 1m, you exert 9.8 N of force over a distance of 1m. Or 9.8 N-m. A very long time ago, someone realized that this was a useful thing to know and gave it a name: "potential energy"
The people who developed these equations and concepts realized that they were all related to each other by the math they were doing. So they called them all different types of "energy". The name for energy of motion was then changed from "vis viva" to "kinetic energy"'. Ultimately though, if they had called it "Isaac's useful quantity" it would still work the same.
[edit] Ehh - not exactly. Energy and mass are equivalent, so increasing the energy of an object increases its mass, which makes it interact more with space.
But energy is not a thing so it doesn't interact with space itself.
No, gravitational energy is a consequence the bending of space.
Correct.
No.
russ_watters said:
Energy does not interact with space. No, he doesn't. Gravitational energy is a consequence the bending of space.
You probably know much more than me, but for the sake of learning something new, bear with me in the argument. :smile:
To my knowledge, everything needs a medium in order to travel. Such as sound energy (requires air in space) or light energy.
How could energy travel from point A to point B if there was no space? In the way that energy travels through space, means that it does indeed interact with it.
Maybe gravitational energy is the consequence of the space bending, but mass energy is what causes the space to bend. Mass creates gravitational energy.
Wow thanks. Very concise explanation.
Love your pictures in your blog too, best of luck.
russ_watters said:
No.
I am not trying to agree with the current view of energy, but rather challenge and improve it (though as limited as my current knowledge is). Of course I do not have mathematical proof (or the ability of making one at this point of my education) but I can start by making small speculations.
Which is why I speculated that heat energy may excite the fabric of space. Not out of arrogance, but for people to scrutinize my statement and point faults in its' logic.
Russ. I don't believe you are doing the question justice invoking Newtonian mechanics and leaving out de Broglie and Einstein.
Though the conclusions one can obtain from de Broglie and Einstein are seemingly incompatible, through Newton's gravitational constant, energy--actually energy density, can be seen equivalent to a particular second derivative of the space-time metric.
This seems unrelated to what Nano-Passion is asking, but I am wondering how energy ties in with mass. If energy and mass could be converted into each other, then are the two somehow perhaps two sides to the same coin?
Energy is Not converted into mass, nor the converse. These are two different ways of measuring the same thing. But, good work. You have unwittingly brought up a third equivalence, I shamefully left out: energy is mass via the equation E=mc2.
(Of course, the quantum field theorist will insist on regauging everything that comes to mind and could propose that E=mc2 + A, such that dE=d(mc2).)
That is absolutely wrong. The object that goes into Einstein Field Equation is the energy-stress tensor. Mass is a scalar quantity. You cannot make a claim that mass is what defines the curvature, because given only the mass density you cannot determine the curvature of space-time. Ergo, it is not the direct cause.
Energy, by itself, isn't it either. It is all possible 4-momentum densities in all possible coordinate systems. Thanks to transformations being linear, it is merely a tensor, rather than some crazy vector functional.Edit: Please keep in mind differences between rest mass, relativistic mass, inertial mass, and gravitational mass. Not all of them are equivalent. When the word "mass" is used by itself, it usually means rest mass, and that means the equation E=mc² isn't even generally true.
What are you talking about? Russ made no such claim dispensing-with other terms of the stress-energy tensor whatsoever. He may be off on a few points but never claimed that mass/energy was the sole contribution to the stress-energy tensor as you say.
Hmm, interesting but confused; well from what I understand, mass in its own existence is equal to energy because when it is destroyed it releases energy thus the law of conversation.
So the destruction of an atom isn't energy because of the atom being destroyed, but the forces that keep it together?
If mass isn't the direct cause of the curvature of space-time then what is?
Hmm.. very interesting that the masses aren't the same. I was aware that mass is different at rest or in motion, but I wasn't aware that gravitational mass is different. How is it so?
Anything which affects the stress-energy tensor will curve spacetime.
http://en.wikipedia.org/wiki/Einstein_field_equations
http://en.wikipedia.org/wiki/Stress-energy_tensor
Your terminology "excites the fabric of space" makes me uncomfortable. In any case I agree with russ wrt the definition of energy. Once a quantity is defined that is what it "really, truly is". Once you have defined a quantity you can then use that definition to determine how it relates to other quantities but that doesn't change what it is, by definition.
Lmao, I apologize for the terminology.
I don't really understand the stress-energy tensor, but I am reading a book about Einstein's statements so I have some catching up to do.
So basically heat energy "stresses" space-time in a way that excites the atoms to move out of position?
What are you talking about? Atoms in an ideal gas at >0K are already constantly moving.
I believe from a modern understanding (I may be wrong, but this is how I learned it) the energy of a system is what give it a time dependence. That is, to move something from "now" to "later" you must give it some energy. An analogy would be with momentum. In order to move something from "here" to "over there", you must give it some momentum (that is it must have motion to get from point A to point B). Einstein unifies space and time, momentum and energy. So since time and space are unifies, one can think of energy as the time component of momentum. We refer to this unified 4-momentum (1 time component, 3 spatial) as being the generators of space-time translations. That is, to move something from "here and now" to "over there and later", you must give something both momentum and energy.
To summarize, ordinary space momentum is the measure motion between spatially separated points (here and over there), and energy is like momentum in time, that is Energy is the measure of motion between to temporally separated points (now and later)
Hope this makes sense
The problem with this approach is that your understanding of energy is very thin, so it is counterproductive to speculate on your own. You're much better off learning what is already known.
Honestly, my own understanding of energy doesn't go very far beyond Newton, so if I left out or glossed over (or erred!) on some of that, I apologize. The conversation moved quickly and based on the level of the original question I'm not sure if this might be doing more harm than good. For most of the energy transfers most people deal with on an everyday basis, those considerations are too insignificant to matter.
Wow, thanks.
I don't believe anything is too insignificant to matter. A thousand years ago people could have argued that the little moving "angels" in the sky were too insignificant to matter.
Basically what I mean is, every question can ultimately lead to more knowledge in physics.
So now I'm under the statement that mass energy curves space-time. Correct?
Then what about Electrical energy? How does it interact with space?
But simply learning what is already known can be counterproductive to your imagination (if you just follow all text blatantly and faithfully). I may be wasting my time (and I apologize if I might be wasting yours), but along the way I am taking advantage of my lack of knowledge to write down ideas (not here, on my notebook)...which may be valuable when I do have all of the knowledge that I need.
That is to say, I am also learning at the moment; though I only took a physics class (classical mechanics pretty much) I am educating myself at the moment by reading books till I take the next class (can't wait =D).
What I was talking about was the relation of heat energy and atoms.
Atoms in an ideal gas at =0K (likely impossible) do not move at all, therefore they have no heat energy. And if they don't move at all, they also have no time sort of speak, I would guess according to relativity.
Yes. But they still have energy (mass) and therefore they still curve spacetime.
Really? Then are all the physics problems I did where two particles moving at relativistic speeds towards each other collide, and a third particle is formed with the energy E = mc^2 of its mass equal to the kinetic energies of the other two particles, pure fantasy? Interesting, I thought my homework problems would at least reflect reality somewhat :-p
But then, if one cannot be turned into the other, how can the two be connected?
I'm not at all sure what this General Physics Folder is for, if not to care for subjects that don't fit well into any other folder. No need to apologize. I don't know at what level questions should be answered either. So it seemed to me, the OP asks how energy should be considered to be defined in more fundamentally terms.
Guys, somehow my main question got sidetracked. Gravitational energy or mass energy bends space. I would like to know how the different types of energy interact with space itself. For instance, how does electric energy interact with space?
I feel that there is something more to it then what is just blatantly told in textbooks.
Yes, I know, I think we have something confused. I was just talking about if heat energy is just space itself vibrating (crazy speculation).
What is your main question as you would now put it?
