How Do Forces Act on an Elevator in Motion and at Rest?
67 replies · 10K views
pinkyjoshi65
A stationary elevator and its contents have a combined mass of 3000Kg. The elevator is suspended by a single cable. (Assume three significant digits.)
Draw a free-body diagram of the elevator and calculate the values of all the forces that are acting on it when at rest.
If the elevator is ascending at a speed of 3.0 m/s, what are the values of the forces acting at this point?
If the elevator is descending at 3.0 m/s2, what are the values of all the forces acting at this point?
For a i did---F_g=mg = 3000*9.8=29400N (Down)
F_g=〖-F〗_T
F_T=29400 N (Up)
For c i did---Net Force downwards=mg-T
downward acceleration= Net force/m= (mg-T)/m
a = g-T/m
T= (g-a)m
= (9.8-3)3000= 20400N(Up)
Net Force acting upwards= mg= 3000*9.8= 29400N(Down)
Is this right? How to do part b?what equation should i use?
It's best to stick with a sign convention, so let's say positive is up and negative is down, ok? So that would make;
Fg = -mg = -29400 ; T = -Fg = 29400
So, now we have the forces at rest. Now, the net force at all times can be written as Fnet = T+Fg. So you have your basic equations set up, all you have to do it equate them with Newton's Second law.
But i part b, they have given the speed, not the acceleration. How do use that in Ma=T+F_g?
Indeed, if an object is traveling at constant speed, what is it's acceleration? What does this mean the net force acting on the object is?
if the elevator is traveling at a constant speed then the a is 0. That means the T and F_g will be equal, so the net force will b 0. Right?
Spot on. And for (c)...?
for c: net force= T+F_g
and we know a=f/m...so a= T+F_g/m
hence then T will be equal to m(a-g)= -20400N. hence tension will be 20400N down, and F_g will be 29400 N Up. Right?
Careful, your numbers are right but check your sign. How do you propose the tension acts downwards and gravity acts upwards?
You were correct in your first post, I just wanted to make sure you understood the importance of defining a definite coordinate system. :smile:
As an aside, an easier method would be just to consider the force required to accelerate the elevator at 3 m/s^2. :smile:
Thank you so much...:)
i had another question..
A rock of mass 200g is attached to a 0.75m long string and swung in a vertical plane.
A) what is the speed that the rock must travel so that its weight at the top of the swing is 0?
B) what is the tension in the string at the bottom of the swing?
C) if the rock is now moved to a horizontal swinging position, what is the angle of the string to the horizontal?
Here is what i could do:
I drew a vertical circle with 2 positions a and b. A is at the top and B is at the bottom. so at A the F_g is down and T is up. at B,T is down and F_g is up. Right? then what?
:bugeye:
i dint understand..so tension is down for A? and T is up for B and F_g is down for B?..k then how do i proceed?
Two points to remember;
(1) The tension always acts towards the centre of the string.
(2) Gravity always acts towards the centre of the earth.
Next, I would draw a FBD for each case individually.
so then at A net force will b mg-T, and at b net force will b T-mg. right? but mg has to b 0 since for part A, weight is 0. that means net force at A will b equal to -T. and we knoe tht centripetal force=Mv^2/r. So that will be -T=-mg=0.2*v^2/0.75. when i solve this i get v=2.71m/s. is that right?
pinkyjoshi65 said:
so then at A net force will b mg-T?
No, at A both forces act in the same direction, i.e. down. Like I said previously, the tension in a string always acts towards the centre of the string.
but then the net force at A will still be -T.so the v will still b 2.71m/s
no we have to find the speed when the weight is 0. dosent that mean that we hve to find the speed when mg=o.that means that only tension force is actin at A. isint that right..?
:redface: My bad, I misread the question, you are indeed correct, your solution is right.
so at B, the tension will b 1.96 N?
how do i find the T at B then?I know that at B the net force will be T-mg. oh wait do i use a as 9.8m/sq sec at B and use that to find the net force. Then i can find T. is that right?
Think about energy conservation. When your rock was at the top, you had some non-zero potential energy. When your rock reaches the bottom of the circular path, where's this potential energy gone?
changes into kinetic energy since it is moving..?
Yup, so now you can work out how fast it's moving at the bottom and hence the required centripetal force, thus leading you to the tension.
but wht is the value for KE..we don't know tht..
You can use conservation of energy to work it out...
(1) What is the change in height between the top and the bottom of the path?
(2) What is the total energy at the top of the path?
(3) All the energy in (2) is converted to kinetic at the bottom of the path, so what's the velocity at the bottom of the path?
change in h will be 0.75m, total energy at the top of the path will b the potential energy=mgh=1.47J. so at B the KE will be 1.47J since no PE exits. right?
tht give me T=5.87N. What about part C?
You might want to check that change in height... draw a picture...
