How do I approach this problem? (Cubes within a larger cube....)
  • Thread starter Thread starter Thiru07
    Approach Cube
The discussion revolves around solving a problem involving a larger cube (8cm x 8cm x 8cm) composed of smaller cubes (1cm x 1cm x 1cm) and determining the sum of numbers on the cubes along the body diagonals. Participants express confusion about visualizing the problem and the method of numbering the smaller cubes, with some suggesting that the numbers represent the smallest volume enclosed by extending the sides of the cubes. There is debate about the visibility of certain cubes and how the numbering works, particularly regarding the numbers 1, 4, 9, and 16. Clarifications are sought on how to approach the problem, especially in terms of the process of "peeling off" layers of cubes and counting those that are multiples of three. The conversation highlights the complexities of interpreting the problem and the necessity for a clear understanding of the cube's structure and numbering system.
Thiru07
A cube of 8cm x 8cm x 8cm is divided into smaller cubes of 1cm x 1cm x 1cm and all the smaller cubes are numbered and arranged to form the larger cube. The smaller cubes are numbered such that the number on the cube represents the smallest volume enclosed by extending the sides of the cube to the outer surface of the largest cube and each cube bears the same number on each surface.
Find the sum of the numbers on the cubes along the two body diagonals of the largest cube.
Volume of a cube = side*side*side
I'm not able to visualise what's given in the problem.
I need a little push here.
This is the only way (in two dimensions) I can think of it, since the question confuses me, too.
I went through it's solution ,
but I hardly understood anything.
So the difference to my interpretation is, that I required an expansion in all directions, and the book only in one direction, the shortest to the outer boundary.
How did you get all those perfect squares of odd numbers?
Can you please explain your 2D structure?
What do you mean by
Then let me choose the version where expansion isn't required to be in all directions.
Here the square (3,4) has a distance of 3 squares to hit the boundary first, here to the top. So a minimum of ##3^2=9## grey squares can be covered without leaving the outer square. The blue one is bigger (25), but as far as I understood it, the smallest one is meant.
Cubes(1cm x 1cm x 1cm) numbered 4,9 and 16 are present inside the largest cube(8cm x 8cm x 8cm) and not on the surface as it appears above in the 2D image right?
If that's the case, then these cubes numbered 4,9 and 16 are invisible right?
Only cubes numbered 1 are visible i.e all the six surfaces have only one numbered cubes .
am I right?
The problem statement doesn't say anything about visibility. In fact, it asks for the numbers of the body diagonal of the large (8,8,8) cube, which aren't visible except of the two at the ends.
I'm getting 4*(1+4+9+16) = 120 as the sum of the numbers on the cubes along the two body diagonals of the largest cube.
What am I doing wrong?
That's the two-dimensional answer. In three dimensions, the squares turn into cubes and the powers turn from ##2## into ##3##.
Thank you fresh_42
I have 3 more questions from the same problem.
1) Find the number of cubes bearing the numbers which are multiple of three.
2) Find the sum of numbers on all the smaller cubes on the surface of the larger cube.
3) Find the number of cubes bearing the number 8 on them.
I have following questions.
We are required to extend the sides of the cube to the furthest outer surface or closest?
If we are required to extend the sides of the cube to the closest outer surface , then all the cubes on all the surfaces will bear number 1 right?
I don't think there's any different extending involved in these three questions.
Edit: I left out the crucial word "different"
haruspex said:
I don't think there's any extending involved in these three questions.
Number of cubes bearing the numbers which are multiple of three is 296
What I'm getting is (4*8)+(4*8)+(4*8) = 96
I missed a lot of cubes. But I don't know which cubes I skipped.
are 1,4,9 and 16 the only numbers smaller cubes can bear?
My understanding of the extension process is that for the given small cube you find the smallest cube which contains it and has an exterior face. Thus, all the surface cubes are numbered 1. If you peel those off, the next layer are all numbered 8, and so on.
The numbers 4 and 9 only arise in the 2D version that fresh_42 used as illustration.
What multiples of three will there be?
Okay, if I peel off twice , I will get a 4x4x4 cube with number 27(multiple of 3) on all 6 faces.
Why do I think that the total number of cubes along all six faces of this 4x4x4 cube is the answer which is 48 and not 296?
Why I'm wrong?
Why I'm wrong?
4x4x4 after two? You start with 8x8x8. After taking off one layer you have 7x7x7... You have to go through all the layers, looking for all multiples of 3.
Previously, I thought peeling off as peeling off all the six surfaces, which reduces the 8x8x8 cube to 6x6x6 cube.
When you say peeling off a layer you mean peeling off just one surface right? i.e After peeling off , you get a 8x8x7 cube. Please correct me if I'm wrong.
Whoops - my blunder.
Yes, sorry, after two you have only 4x4x4 left. So I calculate there are 56 with numbers divisible by 3.
Edit: 296 is the answer to a different question: how many have the number 1?
How did you get 56?
I got only 48 from counting all these 6 surface cubes which are completely covered with number 9.
By the way , Attached is the given solution which I did not understand.
Can you please tell if it makes any sense?
I fold. I have no idea, how the numbering is actually meant to be. I thought I had, but this solutions looks quite different to what I have thought.
Thank you so much for your time and effort :smile:
