How Do I Calculate the Shaft Diameter Based on Gear Forces and Moments?
  • Thread starter Thread starter TyErd
    Gears Shaft
The discussion focuses on calculating the shaft diameter based on tangential and radial forces acting on gears. The calculated tangential forces for Pinion A and Gear B are both 2850 N, while Pinion C and Gear D have tangential forces of 8550 N. The radial forces are 1000 N for Pinion A and Gear B, and 9100 N for Pinion C and Gear D. The torque values calculated are 85.5 Nm for Pinion A, 256.5 Nm for Gear B, 256.5 Nm for Pinion C, and 855 Nm for Gear D, which are essential for determining the shaft diameter using the formula Tmax = (π/16) σmax D³.
  • Understanding of torque calculations in mechanical systems
  • Familiarity with shear stress concepts in materials
  • Knowledge of gear mechanics and force analysis
  • Basic proficiency in using engineering formulas for design
  • Research the application of the formula Tmax = (π/16) σmax D³ in shaft design
  • Learn about calculating shear stress in mechanical components
  • Explore the impact of radial loads on shaft design
  • Study the relationship between gear forces and shaft dimensions in mechanical engineering
Mechanical engineers, design engineers, and students studying gear systems and shaft design will benefit from this discussion, particularly those involved in calculating forces and designing mechanical components.
TyErd
Already calculated:
Tangential Forces :
Pinion A=2850 N
Gear B=2850 N
Pinion C= 8550 N
Gear D= 8550 N
Radial Forces:
Pinion A= 1000 N
Gear B= 1000 N
Pinion C= 9100 N
Gear D= 9100 N
Diameters:
Pinion A= 60mm
Gear B= 180mm
Pinion C= 60mm
Gear D= 200mm
The distances between Gear B and Pinion C for the moment can be said to be X(mm). and the distance between the gears and bearings can be said to be Y(mm).
Moment = F*d
I've attached a picture of how the gears/shaft/bearings are arranged.
My question is how do i calculate the shaft diameter(s)
using the moment formula i know that i can calculate torque for each gear. It would just be the tangential force*the radius of the gear. I have no clue what to do with the radial loads or if I need to calculate any other forces.
any help?
just worked out the torque for each gear:
Pinion A: 85.5 Nm
Gear B: 256.5 Nm
Pinion C: 256.5 Nm
Gear D: 855 Nm
not sure what to do with these...
  • · Replies 26 ·
23K
17K
