How do I connect a USB device to Simulink?
  • Thread starter Thread starter Gean
    Simulink
5 replies · 23K views
Gean
Hello,
I'm new to working with MATLAB and simulink, but I'm trying to connect a USB device with Simulink. Is there any way to connect Simulink with either a USB-port or a COM-port?
Thanks in advance!
You can make use of the built-in MATLAB serial stuff (navigate using the left-hand panel--this just links to the first page):
http://www.mathworks.com/access/helpdesk/help/techdoc/matlab_external/f105659.html
Note, as per the first page I linked to above, that you don't need the Instrument Control Toolbox (extended serial port features and graphical user interface) or Data Acquisition Toolbox if you're just looking to communicate via the serial port.
I tried to make a connection with COM-port, but the problem was that Simulink "sees" only COM port 1 to 8 or something. The connected device is at COM 11.
You can change the port number of a device (well most devices)
control panel->system->hardware->device manager
Select the device (under Ports)->properties->port settings->click advanced
You might have to disable some other devices to free up a low numbered com port first
Allright, i have the com-port set to COM2, which allows me to select it from 'Query Instrument'. However, it does not seem to work.
Like i said, I'm new to the entire Matlab and Simulink thing. I really have no idea how to use the built-in Matlab stuff :(
Right: which is why I link to the documentation! Read through the stuff on the left hand side under serial interface and you'll be able to find some examples to help you with your application.
EDIT: Whoops! Didn't realize that link didn't autoload the left-hand menu. Click the first link (What is the MATLAB Serial Port Interface) under the "On This Page" box to have the left-hand menu open up the Serial Port I/O pages.
