How do I determine if an operator is Hermitian?
Axiom17
I have some operators, and need to figure out which ones are Hermitian (or not).
For example:
1. [tex]\hat{A} \psi(x) \equiv exp(ix) \psi(x)[/tex]
I have defined the Hermitian Operator:
[tex]A_{ab} \equiv A_{ba}^{*}[/tex]
I just don't know where to start with this :rolleyes:
One good way is to see if something is hermitian is if
[tex]\langle \psi | A | \psi \rangle= \langle \psi |A| \psi \rangle^*[/tex]
if A is hermitian then the equality will hold.
The way you expressed the opeator A_{ab}=A*_{ba} is a matrix notation, useful when acting on a set of vectors like v_{b}. But in your problem, how does the operator act on the wavefuntion Psi(x)? Can you re-express your definition above for Hermiticity in this specific case?
Umm I have this:
[tex]\langle a|\hat{A}|b \rangle = \int dV \psi_{a}^{*}(r)r^{2}\psi_{b}(r)=[\langle b|\hat{A}|a \rangle]^{*}[/tex]
But I don't know if that's any use
So, for example
[tex]\langle \psi | A | \psi \rangle= \int \psi^*(x) exp(ix) \psi(x)[/tex]
[tex]\langle \psi | A | \psi \rangle^*= \int \psi^*(x) exp(ix)^* \psi(x)=\int \psi^*(x) exp(-ix) \psi(x) \neq \int \psi^*(x) exp(ix) \psi(x)[/tex]
The operator is not hermitian.
