How do I evaluate this log function?
  • Thread starter Thread starter feihong47
    Function Log
The discussion revolves around evaluating a logarithmic function expressed as the product of several logarithms: (log23)(log34)(log45)...(log3132). The original poster expresses difficulty in finding the solution without a calculator, noting that the answer is 5 but not understanding how to arrive at that conclusion.
  • Some participants suggest using the change of base formula for logarithms, while others explore the implications of the logarithmic properties and the relationship between the terms in the product.
Participants are actively engaging with the problem, with some providing insights into logarithmic identities and properties. There is a recognition of different approaches being discussed, but no explicit consensus has been reached on a single method to solve the problem.
The original poster mentions a restriction on using calculators, which may influence the methods discussed. Additionally, there is a note about the use of LaTeX for mathematical expressions, indicating a focus on clarity in communication.
feihong47
I assume I can't use a calculator obviously.. so I'm quite stuck. The answer is 5, but I have no idea how to get that.
(log23)(log34)(log45) ... (log3132)
Use the fact that
$$\log_b a = \frac{\log_c a}{\log_c b}$$
for any positive, real numbers a, b and c (with c > 1).
That was a fast response, and a fact that I didn't know. How do I create equations on this forum BTW?
You use LaTeX, that is, the [ itex ][ /itex ] -tags (remove the spaces) . There's a guide in the forums somewhere if you're not familiar with it, I'll edit a link to it to this post if I find it. You can also open the "LaTeX Reference" by clicking the Σ in the toolbar.
If you don't have to write anything complicated, you can just use the quick symbols and x2 and x2 buttons in the toolbar. LaTeX looks a lot nicer & it's easier to read, though.
EDIT: Here's the LaTeX guide.
You could also approach this as follows:
Let [itex]\displaystyle y=(\log_{2}3)\,(\log_{3}4)\,(\log_{4}5)\,\dots\,( \log_{31}32)[/itex]
Then, [itex]\displaystyle 2^y=2^{(\,(\log_{2}3)\,(\log_{3}4)\,(\log_{4}5)\, \dots\,( \log_{31}32)\,)}[/itex]
By laws of exponents and the definition of a logarithm,
[itex]2^{(\,(\log_{2}3)\,(\log_{3}4)\,(\log_{4}5)\, \dots\,( \log_{31}32)\,)}[/itex]
[itex]=\left(2^{(\log_{2}3)}\right)^{(\,(\log_{3}4)\,( \log_{4}5)\, \dots\,( \log_{31}32)\,)}[/itex]
[itex]=3^{(\,(\log_{3}4)\,( \log_{4}5)\, \dots\,( \log_{31}32)\,)}[/itex]
[itex]=\left(3^{(\log_{3}4)}\right)^{(\,( \log_{4}5)\, \dots\,( \log_{31}32)\,)}[/itex]
[itex]=4^{(\,( \log_{4}5)\, \dots\,( \log_{31}32)\,)}[/itex]
etc.
[itex]=\left(31^{(\log_{31}32)}\right)[/itex]
[itex]=32[/itex]
So, just in case others misunderstand, [itex]2^y= 32= 2^5[/itex] and therefore, y= 5 as the original poster said.
Very nice approach. Thanks!
  • · Replies 19 ·
