How do I evaluate this Poisson distribution?
13 replies · 4K views
KAISER91
So I have figured out what the values for lambda and x are, but I don't know how to evaluate once I plug the values into the formula.
λ = 20
x = 18
= [ e^-20 x 20^18 ] / 18!
exp -20 x 20^18 is easy to find but how do plug in 18 factorial in the calculator?
micromass said:
Simple do 18.17.16.15.14.13.12.11.10.9.8.7.6.5.4.3.2
I'm not sure what you mean.
The answer to the question is 0.0844
micromass said:
What does 18! mean?
I think it simply means the factorial of 18
It's from the Poisson probability distribution formula, which is;
f (x) = (e^-lambda x lambda^x ) / x!
And I just plugged in the values of x and lambda
I'm not sure how to evaluate this
Well, there is usually a factorial button in your calculator, somewhere.
Try under the MATH menu.
I have tried that several times but keep coming up with the wrong answer.
LOLI think it may be something else I'm doing wrong.e^-20 simply means the exponential of -20 ? right??
Yep, I see the factorial button.
I'm using a CASIO 100 so it's simply shift + x^-1 on the calculator.
Well, your formula should be correct. Are you sure your x and [itex]\lambda[/itex] values are correct?
Yes I'm sure.
Let me take a screenshot of it for you.
Well, I get the same answer as the book, so your calculations must be wrong somewhere.
Yep.
Nevermind, I have found out my problem.
I was using the wrong button on the calculator for exponential.
LOL
