How do i find the friction force without μ or acceleration?
The discussion revolves around determining the friction force without knowing the coefficient of friction (μ) or acceleration. Participants are exploring the relationship between different surfaces and the forces involved in friction, particularly in a practical experimental context.
  • Participants are considering the surfaces involved in friction and questioning the tools available for measuring forces. There is discussion about using a bathroom scale and how it might relate to measuring tension or friction. Some participants suggest experimental setups to find static and kinetic friction, while others are probing the assumptions behind using weight and gravitational force.
The discussion is active, with participants raising questions about the feasibility of measuring friction using available tools. Some guidance has been offered regarding potential experimental methods, but there is no consensus on a specific approach yet.
Participants are working within the constraints of a homework assignment, which may limit the tools and methods they can use. There is an emphasis on understanding the relationship between weight, force, and friction in a practical setting.
helppmeee
I need to find the static and kinetic coefficient of a desk for a physics lab. we have pulleys, string, a scale, a "car" and a few other things. How would I find the force of friction?
no idea
Friction involves two surfaces. What are they? Or do you mean rolling resistance?
The "scale" is as in a weighing scale?
What other things?
What other things?
I guess the desk and the floor.
scale is for weighing yes. things that can be used for weight (like paper, beads etc.), measuring tape and i think that's it but we are allowed to bring anything else we want.
Which of all the items you listed can directly measure a force?
nothing? there's a way for sure i just can't think of anything. does anything come to mind?
If your 'scale' can measure tension in a string, just attach it to object(s) and pull - take reading at the point where the object(s) just begin to move. Alternatively increase slope of surface till object just begins to slide - then ##μ_s=tan(θ) ## if I remember correctly. I can't quite see how to do kinetic friction but I'd guess you will need some kind of 'ticker timer' experiment whereby the object(s) are pulled along the table surface by a falling weight of known value. You should be able to calculate coefficient of kinetic friction if you can obtain a value for the acceleration of falling mass and/or mass sliding on the table.
Please do not provide answers so early. Try nudging a little first. The student must be encouraged to think.
by scale i mean bathroom scale
how would my bathroom scale measure the tension in string
Doesn't that measure force?
It can measure the force provided by the weight of a mass. How could you use that weight?
force of gravity. i need force of friction
weight is equal to force of gravity...
i could get the mass from the weight...
thats all i can think of
How could you use the weight of the mass?
What do you need the desk to do if you are going to find the maximum static frictional force it has from the floor?
i would need to get the desk to start moving
would the weight which equals to force of gravity be equal to force Newton which is the same as force tension?
If you use weight in the right way, yes.
Gravitational force is horizontal. What direction do you need the force on the desk? How can you arrange that?
241779
it would look like that (ignore the masses labelled)
Right. What would your procedure be to find the static frictional force?
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 20 ·
