How do I reduce the outer loop in the first question with 3 inputs?
11 replies · 2K views
John54321
Note -- you must show your work on schoolwork problems before we can offer tutorial help
I have got 2 questions like this and I'm struggling any help would be much appreciated please. Thanks
Just reduce loop by loop, inside out.
Use Masons rule. Rightmost inner "loop" is just an addition: G3 + G4.
Thanks for the quick response, I will try and understand what you've written and look at masons rule.
Hesch said:
Use Masons rule.
Masons rule says, that if you have a loop with a forward feeding block, G, and a negative back-feeding block, H, the transfer function of the reduced block will be:
G / ( 1 + G * H )
Now the leftmost inner block has positive feed back, so the transfer function for this loop will be:
( G1 * G2 ) / ( 1 - G1 * G2 * H1 )
Thanks very much for explaining this, now I've got to draw this out step by step. Much appreciated.
Thanks
John
Hi
So will the inner right loop be (G3 + G4) ?
Thanks
Yes: input*G3 + input*G4 = input*(G3+G4) = output.
Transfer function = output/input = (G3+G4).
Hi
So this is how it should look with the two transformations ?
Thanks for help
It's not a transformation, it's a reduction of the Laplace transformed.
The reduced transfer function (leftmost inner loop) must be drawn as one block wherein there is a fraction: Numerator = (G1*G2), denominator = (1 - G1*G2*H1).
Otherwise your drawn transfer function will be read as: ( G1*G2 ) * ( 1 - G1*G2*H1 ).
Hi
Ok thanks very much for your help now the next question looks more involved.
Hi which I'm put would I start with as there are 3 ? Please thanks for your help
Did you reduce the outer loop in the first question?
I don't quite understand your question ( maybe because I'm not american or english ): 3 of what? Inputs? Please reword your question.
Furthermore I don't understand what is meant by the question in 2): Describe the relationship . . . ?
You can "move" θd1 and θd2 backwards in the loop, dividing them with the transfer function they are passing by this movement. Doing this you will have one (parallel) input:
θi + ( θd1/G1 ) + ( θd2/(H2*G2*G1) ).
Having removed the inputs from the loop, you can reduce the loop, and multiply its transfer function by its 3 inputs in parallel.
( My best guess ).
