How do I solve a cubic ODE using a series solution?
8 replies · 3K views
Winzer
Find the solution to the ODE via the power series:
[tex]y = \Sigma_{i=0} a_j x^{2j + m}[/tex]
[tex]y' - y^3 = 0[/tex]
I get
[tex]\Sigma_{i=0} a_j (2j+m) x^{2j+m-1} - \Sigma_{i=0} (a_j)^3 x^{3(2j + m)}[/tex] = 0
I don't know how to deal with the cubic part. No matter where I start my series I can't get the recursion relation without x
I get
The summation on the right above is incorrect. y^3 is the cube of the summation, not the summation of the cubes of its terms.
It will probably be helpful to work with the a few terms of the expanded series, rather than work with the closed forms of the series. The equation above should be written as follows.
[tex]\Sigma_{i=0} a_j (2j+m) x^{2j+m-1} - \left(\Sigma_{i=0} (a_j) x^{2j + m}\right)^3[/tex]
Thanks for the correction.
So it looks like I would have to expand the cubic part to just a couple terms?
Where do you go from there?
Expand both parts and combine like terms. You'll probably need to expand to more than just two terms, though. I haven't worked this problem, but that's the tack I would take.
The equation is separable, so you can solve it using that technique as a check of your work using series.
I don't see how expanding and combining like terms will set me up for a recursion relation.
I'm not sure this is what you want, but it's the only way I know how to express that DE in terms of a power series. ll do the square via Cauchy product:
[tex]\begin{aligned}<br /> \sum_{n=0}^{\infty} a_n x^n \sum_{n=0}^{\infty} a_n x^n &=\sum_{n=0}^{\infty}\sum_{k=0}^n a_k a_{n-k} x^n \\<br /> &=\sum_{n=0}^{\infty} b_n x^n,\quad b_n=\sum_{k=0}^{n} a_k a_{n-k}<br /> \end{aligned}[/tex]
Now, how would express:
[tex]\sum_{n=0}^{\infty} a_n x^n \sum_{n=0}^{\infty} b_n x^n[/tex]
So I am still having problems
for m = 0 I get:
[tex] a_{i} i x^{i-1} - (a_{i} x^i)^3 =0 [/tex]
which becomes
[tex] a_{i+1} (i+1) x^{i} - (a_{i} x^i)^3 =0 [/tex]
so for i = 0
[tex] a_1= a_0[/tex]
for i =1
[tex] a_2(2)x - (a_{1}^3 x^3) = 0[/tex]
which is
[tex] a_2(2) - (a_{1}^3 x^2) = 0[/tex]
Is this right? having an x in the coefficient for a2?
