How do I solve an exponential equation with different bases?
  • Thread starter Thread starter babacanoosh
    Exponential
The discussion revolves around solving an exponential equation involving different bases, specifically the equation 2^(x^2) * 4^(2x) = 1/8. Participants explore methods to manipulate the equation to make the bases consistent.
  • Participants discuss the approach of rewriting the equation with a common base, questioning the steps taken and the transformations applied. Some express uncertainty about their calculations and the implications of their results, particularly regarding the nature of the solutions (real vs. imaginary).
The discussion is active, with participants providing insights into the problem and correcting each other's misunderstandings. There is acknowledgment of potential mistakes and a focus on clarifying the correct approach to the equation.
Some participants mention the possibility of obtaining imaginary solutions, while others assert that the equation yields real roots. There is a noted confusion regarding the manipulation of the equation and the interpretation of the results.
babacanoosh
Hello all, I can't believe I having a hard time with this problem but...I am :cry:1. 2^(x^2) X 4^(2x) = 1/8
2. make the bases the same?
3.
2^(x^2) X 2^((2x)^2) = 1/8
2^(3x^(2)) = 1/8
3x^(2)log2=log1/8
(log1/8)/(log2) = 3x^(2)
x^(2) = -1
I know I am doing it wrong. Any help would be greatly appreciated. Thanks,
Baba
(2^{2x})^2=2^{4x}
The general rule for "exponentiated exponents" is
(a^b)^c = a^{(b \cdot c), for a positive base a .
For this problem, you will end up with a quadratic equation in x, with two solutions.
great! thanks so much. Just a stupid mistake on my part, I knew that :rolleyes:
I believe you end up with two imaginary solutions; My guess is that you should just show your work until you run into negative square root.
You actually get two real roots.
I found the same, you should get two real roots.
Oh, I see what I did wrong, I had 2^{x^2}(2^x + 2^x)=1/8, instead of 2^{x^2}*2^x*2^x=1/8
  • · Replies 18 ·
  • · Replies 21 ·
