How do I solve for rotational dynamics using Newton's second law?
20 replies · 3K views
Dusty912
I attached the stated questions. Mainly need help with question 2. See below for my answer to question 1.
ΣT=Iα
ΣF=ma
moment of inertia of sphere: I=(2mR^2)/5
moment of inertia of disk: I=(mr^2)/2
v=rω
V(center of mas)=V(tangential) -because of smooth rolling
ΔΘ=ωt+(1/2)αt^2
ω(final)=ω(initial)+αt
ω^2(final)=ω^2(initial) +2αΔΘ
1. C) 4F1 -I figure the lever arm is 1/4 as big for the smaller disk so it would require a force 4 times as big to counteract the force applied to the larger disk.
2. a) I know how to draw the FBD for this.
B) what I need the most help with. It has been a while since we have done this section and I had trouble with it the first time. But I am assuming we use the analogy for Newton's second law ΣT=Iα and the sum the torques. But do I do this for the sphere and the the disk together? not really sure. My guess is that it would look something like this. T1=the tension in the rope tangential to the sphere and disk.
T2=the tension in the rope tangential to the disk and connected to the block.
So summing the torques for the sphere: T1R=(2/5)mR^2α -the radius would be of the sphere of course
Summing of the torques for the disk: T2r=(1/2)mr^2α
and summing of the forces for the block would be T2-mg=ma (the m's would be the mass of the block)
from here I'm stuck. Sorry I couldn't show more work but like I said I really need help with this one.
Part (c) should be pretty easy once I know the acceleration of the black from part B
Basically, there are two tensions in the string.
One tension accelerates the sphere.
The other tension is between the disk and the mass.
The difference of these tensions accelerates the disk.
Okay that somewhat helped. But I'm not really sure what I should do with that information. Could you elaborate? or anyone else care to add on?
okay so this is what I have so far: I summed the forces for the block resulting in T2=m2g-m2a
then I summed the torques for the sphere resulting in: T1R=(2/5)MR^2α then I used the relationship between tangential acceleration and alpha at=Rα and subbed in α resulting in T1=(2/5)Mat then I summed the torques for the disk resulting in : T1r-T2r=Iα then subbing in α and the moment of inertia for a disk and canceling all of the radii yields T1-T2=(1/2)m1at subbing in T1 and T2 and solving for at yields
at=(m2g)/((2/5)Mat+m2-(1/2)m1)
which gave me 2.58m/s
Am I in the ballpark?
oh and by the way I'm now using the variables from the attached document, sorry for the confusion
haruspex said:
Just to clarify, those two uses of alpha are for different angular accelerations, yes?
yes they are, sorry knew I should have clarified that
Ok.
Your equation for at in post #4 doesn't look right. Does it make sense that increasing the mass of the disk would increase the acceleration?
Even with the equation as you have it, your final numerical answer looks about ten times too large.
okay so are you saying I did something wrong in my algebra?
haruspex said:
Ok.
wouldn't increasing the mass of the disk make the acceleration smaller? just for clarification m2 is the block and m1 is the black
Quite so, but your equation says otherwise. Check the signs. If you cannot spot the error, post all your steps.
(The black?)
(The black?)
sorry m1 is the disk, and I am looking at it now. So I'm on the right track then?
Yes, there is just the one error in the equation, and it looks like you had an arithmetic error later too.
Okay so I'm still getting the same answer here are my steps:
1.I summed the forces for the block and solved for T2 T2=m2g-m2a
2.then I summed the torques for the sphere and solved for T1 and subbed in a=Rα for α. The R's cancel and yield T1=(2/5)Ma
3.then I sum the torques for the disk and sub in a=rα for α. That yields: T1-T2=(1/2)m1a
4. then I substitute T1 and T2 into the disk torque summation which yields: (2/5) Mat-m2g +m2at=(1/2)m1at
5. I move the terms with at onto one side and factor out at yielding: at((2/5)M +m2-(1/2)m1)=m2g
6. then I solve for at yielding at=(m2g)/((2/5)M+m2-(1/2)m1)
Which ways do T1 and T2 act? Which way does the disk accelerate?
oh I see so:
at=(m2g)/((1/2)m1 +m2 +(2/5)M)
okay thank you and as far as question #1 goes would C) 4F1 be correct?
haruspex said:
Yes.
haruspex said:
Yes.
So I already turned in my quiz, but I was a little curious about the radii canceling out. Since that was information given to me, I figured Id have to use them.
In the real world, there may be a lot of available information that turns out to be redundant in solving the problem at hand. So I endorse the provision of surplus information in questions. Were that done more commonly, it would not have bothered you that information provided was not used. Note also you were admonished to work purely algebraically until the final step. Had you plugged in numbers along the way, you might never have noticed that the radii were not relevant.
