How do I solve this polynomial limit?
9 replies · 2K views · last reply
greg_rack
Same as the other thread I opened... this function is literally messing me up :)
$$\lim_{x \to +\infty }\sqrt{x^{2}-2x}-x+1$$
none
I'll write my considerations which lead me to get stuck on the ##\infty-\infty## form.
$$\lim_{x \to +\infty }\sqrt{x^{2}-2x}-x+1 \rightarrow |x|\sqrt{1-0}-x+1$$
And I have no idea on how to go on...
You could rewrite it:
\begin{align*}
\lim_{x \to \infty}\left(\sqrt{x^2-2x}-x+1\right)&=\lim_{x \to \infty}\left(\sqrt{(x-1)^2-1}-(x-1)\right)\\&=\lim_{y \to \infty}\left(\sqrt{y^2-1}-y\right)\\
&=\lim_{y \to \infty}\left(\sqrt{y^2-1}-\sqrt{y^2}\right)
\end{align*}
and consider whether the difference between these two roots tend to zero or not.
[tex]\sqrt{x^2-2x}-x+1=\frac{x^2-2x-(x-1)^2}{\sqrt{x^2-2x}+x-1}[/tex]
You almost did all the job.. Because we are taking the limit at ##x\to+\infty## , x is positive in a neighborhood of ##+\infty## thereforce you can replace ##|x|=x##.
So we obtain that limit tending to 1, right? ##x-x+1## indeed... but it doesn't work and I can't get what's wrong
Oh yes, it does tend to zero now, and that should be correct... but why was the ##x-x+1## wrong? All I did was simply take the ##x^2## out of the root
And what about the limit with ##x \to -\infty## of that same function? I'm stuck again, since the form now is ##\infty+\infty##
You did more. You had ##x\sqrt{1-\dfrac{2}{x}}-x+1## and only let the ##2/x## term go to infinity, so you got indeed ##\infty-\infty+1## which could be any number.
Thanks man, now I got what I was doing wrong!
From post #2 by @fresh_42,
$$\sqrt{y^2-1}-\sqrt{y^2}=\frac{\left(\sqrt{y^2-1}\right)^2-\left(\sqrt{y^2}\right)^2}{\sqrt{y^2-1}+\sqrt{y^2}}.$$Simplify the numerator and consider what happens to the denominator in the limit ##y \rightarrow \infty.##
This case is easier. One blow up plus a second blow up is still an explosion. You only have to pay attention if terms seem to cancel each other. In such a case you have to look closer on the degree or speed of cancellation. ##\infty - \infty## and ##\dfrac{\infty}{\infty}## are not defined, i.e. you have to transform the expression until they are either defined or you can otherwise come to a conclusion. E.g. if you take my transformation with the ##y## and combine it with the trick in post #3: ##\sqrt{...}-\sqrt{...}=\dfrac{\sqrt{...}^2-\sqrt{...}^2}{\sqrt{...}+\sqrt{...}}## then you get a form where it is clear how it behaves.
