How Do I Solve Titrations and Buffer Calculations in Chemistry Homework?
  • Thread starter Thread starter bohemian
    Buffers
This discussion focuses on solving titration and buffer calculation problems in chemistry homework. The first question involves determining the molar mass of a metal carbonate (MCO3) through a back-titration method using HCl and NaOH. The second question requires calculating the volume of 6.0 M NaOH needed to adjust the pH of a buffer solution containing acetic acid and sodium acetate to 5.75. Key reactions include the neutralization of HCl with NaOH and the reaction of MCO3 with HCl.
  • Understanding of molar mass calculations
  • Knowledge of titration techniques, specifically back-titration
  • Familiarity with buffer solutions and pH calculations
  • Basic chemical reaction equations involving acids and bases
  • Study back-titration methods in analytical chemistry
  • Learn how to calculate molar mass from titration data
  • Explore buffer solution chemistry and the Henderson-Hasselbalch equation
  • Practice calculating pH changes in buffer solutions with strong bases
Chemistry students, educators, and anyone involved in analytical chemistry who needs to understand titration methods and buffer calculations for academic or practical applications.
bohemian
I have two homework questions that don't make sense at all. I don't really know what formulas to use exactly. Here they are:
1. Molar mass of a certain metal carbonate, MCO3, can be determined by adding an excess of HCl acid to react with the carbonate and then "back-titrating" the remaining acid with NaOH.
a. Write an equation for these reactions
b. In a certain experiment, 20.00 ml of 0.800M HCl were added to a O.1022 gram sample of MCO3. The excess HCl required 5.64 ml of 0.1000M NaOH for neutralization. Calculate the molar mass of the carbonate and identify M.
and
2. Calculate the volume in ml of 6.0 M NaOH that must be added to 0.500 L of a buffer made of 0.0200M acetic acid and 0.0250M sodium acetate, in order to obtain a final pH of 5.75.
Any help to get me started on these would be greatly appreciated. My homework is due on Wed. so if anyone could reply back before then, that would be great. Thank you.
Chemistry news on Phys.org
I can help u with the first.From the notation,i'd suspect that the metal ion is divalent so the reactions would go
MCO_{3}+2HCl\rightarrow MCl_{2}+CO_{2}\uparrow+H_{2}O
NaOH+HCl\rightarrow H_{2}O+NaCl
Daniel.
Thank you for your help.
Did u do the arithmetics...?It's really useful to use mols all the way.
Daniel.
26K
