How do I transform a matrix from one basis to another?
  • Thread starter Thread starter transgalactic
    Transformation
7 replies · 2K views
transgalactic
i added a link with the question
and a solution
http://img518.imageshack.us/my.php?image=img8267rf4.jpg
i want to transform a matrix from a standart basis to basis B
A-out old matrix
X- the old basis
Y-the new basis
S-the transformation matrix
S^-1 -its inverse
N-resolt
i did
Y|X>>>I|S
S|I=I|S^-1
N=S*A*S^-1
in some metrices i got fractures so i multiplied by the dinominator the whole line
that what i did
i don't know where i did a mistake
or wether this method is ok
i tried many times to solve it but i can't get nor to the formal answer nor
to understand the formal solution
can some solve it from the start to the end
Sorry, I didn't look closely enough. You have, as the inverse to
[tex]S^{-1}= \left(\begin{array}{ccc} 2 & -1 & 1 \\ 1 & 2 & 0 \\ 1 & 1 & 1 \end{array}\right)[/tex]
[tex]S= \left(\begin{array}{ccc} \frac{1}{2} & \frac{1}{2} & -\frac{1}{2} \\ -\frac{1}{4} & \frac{1}{4} & \frac{1}{4} \\ -\frac{1}{4} & -\frac{3}{4} & \frac{5}{4} \end{array}\right)[/tex]
That is correct.
However, in "S*A*S-1" you have removed the denominators! Why did you do that? I know you said "i got fractures so i multiplied by the dinominator the whole line" but that, of course, changes the matrix. You will need to go back and divide each line by that multiplier.
i can't get to the answer of the solution that i was given
i am not sure about how to build the S matrix
(of transformation from one basis to the other)
My question was "Why didn't you use that?"
i did use that
as you can see in my soltuion i multiplied the first one by 2
the second one by 4
and the third one by 4
so as you you said i need to divide the resolt by these numbers
i took the resolt
and i tried to divide the rows by
1/32
but no way that whould give me the formal answer
