How do nodes and antinodes form in standing waves?
76 replies · 22K views
In a standing wave, therefore, all points between each pair of concecutive nodes will have a constant phase difference because the wave is not propagating and it is being produced by the superposition of two other waves. So each point is moving at the same rate relative to the next point along the wave. THIS IS NOT to say that adjacent points in the standing wave DONT have a different phase relationship, right?
Please reread post#22
All the particles in a stationary wave vibrate in phase.
I think I get that now.
Now for harmonics!
harmonics simply vibrations of any kind that repeat themselves. In music terms, the fundamental frequency, or first harmonic, is the lowest frequency at which resonance occurs. This type of wave has two nodes and one anti node.
The second harmonic (second frequency at which resonance occurs) is when we have three nodes and two anti-nodes.
etc...
I know we covered this earlier but I wanted to show what I know as an introduction to the question:
when and why would several (or all) the fundamental frequencies / overtones be produced at once
thanks
First, please note that harmonics can occur in both standing and traveling waves.
A 'pure' tone or wave is just the fundamental. The fundamental carries the lowest energy.
All real world oscillators create the fundamental plus some % harmonics. It is a great design challenge to reduce this % if the harmonics are unwanted.
Generally, the greater the energy input in creating the wave, the greater the % harmonics created.
If you have ever blown into wind instrument such as a flute or recorder, or even a whistle, you will have experienced the difference between what happens when you blow hard or softly. The harder you blow the 'harsher' the sound. The harshness is due to the harmonic content.
You did ask, backalong, why there is a phase change at a boundary.
This animation provides a mechaical, non mathematical, explanation.
Ask again if you do not understand it.
http://paws.kettering.edu/~drussell/Demos/reflect/reflect.html
So what you are saying is that a lower energy will, say, only produce the first harmonic but a higher energy will produce, say, the first second and third harmonic? If we then were to combine these, would it be like the superposition of waves?
With a propagating wave, would this simply be the number of waves per unit length?
According to the 'hard boundary' reflection the wave changes because of a Newton pair. BUT if there is compression at the end of the string, as there appears to be, should not the reflected wave exhibit these compressed properties?
If we look at the soft boundary, is this example like the one from before - where we move a string around in air (no rigid boundary). There is therefore no phase change in this reflection BUT a standing wave is still produced?
Basically.
If you start with only enough energy to generate the fundamental then that is all you get.
Using more energy allows some first, second, third etc to be generated. Some systems only allow odd harmonics or even harmonics.
This idea is fundamental. It comes out in many ways so for instance, when you study the quantum theory the lowest energy configuration is occupied first by a system and then the next and so on.
A propagating wave with harmonics is still apropagating wave, it just has a different wave shape.
Herein lies a wonderful tieup between maths and physics. The maths says that the basic wave is sinusoidal. However Fourier theory also says that almost any repetitive waveshape can be represented or built up from a fundamental (of the same frequency) plus suitable % of harmonics.
Don't forget that the animation is of an ideal string. An ideal string cannot generate standing waves if it has a free end.
Try to get hold of the concepts first, but keep going.
Studiot said:
Basically.
In post #24 SC says "Remember, at a 'loose' end, there is an antinode so the phase of the reflection will be unchanged - a maximum is formed."
Based on what you just said "An ideal string cannot generate standing waves if it has a free end." would the motion of the string be totally dependent on the force applied by the thing moving it (say the hand). If the amplitude is 0.5m as provided by the hand, it will always be 0.5m.
If we presume a hard-boundary, then the maximum amplitude could be 1 m? right?
I shall actually try the experiment and see if it is true but I wanted to check the theory before the experiment
thanks
I did the experiment and this is what I think i observed:
I took the string and waved it about round and round. There was no apparent standing wave. The maximum amplitude was dependent totally on how I move the string.
There was a node where I move the string and another about a wavelength away (2 nodes) and from what I could see, two anti-nodes BUT I may be wrong!
I then tried producing a standing wave: one node end at my hand, the other supported by an object - did not work - shame!
On a practical note: I have to point out that harmonics are exact multiples of a fundamental frequency. In resonant systems - standing waves and others - the higher order frequencies at which resonance occurs can, in no way, be relied upon to be exact multiples of the fundamental. They should be referred to as overtones.
The frequency difference between a harmonic and an overtone may not be much but it is enough to give a musical instrument its characteristic sound. Also, if you ever need to buy a quartz crystal for use in an oscillator, you will find that some crystals are specified to be operated at overtone frequencies and that the overtone frequency will usually not be harmonically related to the crystal fundamental. The 'node' pattern will be as you'd expect to find it but, because of the effects at the ends, the exact positions may well be shifted.
does this imply that every instrument has a slightly different difference between the the harmonic and the overtone - this also, presumably, depends on the amount of energy put into the system?
As long as you are operating in the linear region, the amplitude should make no difference. But the impedance of the driving source (and the loading of the detector) could affect things subtly.
According to the dictionary impedance,
"the impedance of a load is the resistance of the load and is its reactance". WHat has this to do with harmonics and overtones
Fair question----
Putting power into a system and taking it out (measurement) involves connecting to that system. Any practical source of power (amplifier) has an impedance which is not 'ideal' (i.e. not zero or infinite). This constitutes a 'load' on the resonator and can affect the phase and amplitude of the reflected waves. This is equivalent to altering the characteristics of the resonator and can change the resonant frequency. An example of this could be bending the note on a mouth organ reed by sucking hard.
In the discussion I noted that you will not get standing waves in a string with a totally free end.
Under certain conditions it is possible to get the string end to exhibit chaotic behaviour, I think the poplar term is 'the strange attractor' for this.
Since we are talking about mechanical oscillations we need the mechanical definition of impedance.
This is the ratio of the force needed to move a body to the velocity achieved by said movement.
Thanks so much guys for all your help! I really appreciate it!
I know I seemed to close the topic but I have a really quick last question on this point:
If I superimpose to longitudinal waves on each-other (drawn as wave-fronts) do i simply get an double amplitude if they are in phase and have the same frequency and amplitude as each other.
Here is what I mean:
Wave 1: ¦¦¦¦¦¦¦¦¦¦
Wave 2: ¦¦¦¦¦¦¦¦¦¦
(ignore the bits in-between each wave front ¦ - the middle bit)
Superimposed wave: ¦ ¦ ¦ ¦ ¦ ¦
is that correct
There is always some quantity that you can plot as an X - Y graph for a longitutinal wave.
In the case of sound waves, which are longitudinal waves, that quantity is pressure.
A plot of pressure along any straight line taken as the x-axis will show the typical sinusoidal variation.
Longitudinal waves can participate in constructive and destructive interference and standing waves, just as transverse ones. You add the quantity (eg pressure) varying as above, rather than particle displacement amplitude todescribe the whole wave.
Why do I use pressure? not speed or displacement?
Whatever direction the displacement takes place in, you can still get a resultant when two waves coincide. I think your diagrams may be confusing wave fronts with displacement.
You can use pressure (which corresponds to displacement) or speed (average speed, if it's a gas). The pressure max will be at a velocity min, of course. You can still do the sums but it's normal to consider displacement as it's zero at a wall.
Wavefronts are point on a wave that join up all adjacent points.
Displacement is the maximum distance traveled from resting point.
On my diagram, the point between two lines represents the distance between two new waves - ah I see why I got confused!
How then would I draw a displacement graph for a longitudinal wave or does this not exist?
You must have done the kinetic theory by now.
Sound is a pressure wave.
Pressure is the average result of the movement of a large number of individual particles, not in any way aligned like in a transverse wave.
So, on average, the pressure ( ie particle concentration) at any location varies periodically. Individual particles may be moving in widely different patterns and speeds. Tracking the actions of any single particle will not lead to a wave.
I have uploaded a question here about waves and superposition http://www.mediafire.com/file/bg6raawvbv8mbts/A%20loudspeaker%20is%20connected%20to%20a%20signal%20generator1.doc
here are my answers. Could you please check them:
"Questions"
a) Explain why the minima never have a zero value. [2]
b) As the microphone is moved towards the metal plate, the amplitudes at the minima gradually decrease. Suggest why this happens. [2]
"My answers"
a) the reflected wave will have less energy than the wave produced by the speaker. This means the amplitudes of the both waves cannot destroy one another (interfere totally deconstructivl) as the two amplitudes are not of equal magnitude
b) The sound wave produced by the sound emitted from the microphone will have lost energy as it propagates towards the microphone - hence the amplitudes of the waves will be smaller.
The path difference decreases as the microphone moves closer to the metal plate, so the energy level of both waves will be more similar, as will the amplitudes, so the deconstructive interference becomes more obvious.
How do you rate these answers? are they even correct?
You mean apart from the obvious howler in (b) ?
(a) The pressure variation in the sound is about an average value. Obviously the pressure can never actually be negative . Can it be zero?
(b) You got the general idea. Obviously the power in the reflected wave can never be greater than the incident. The power emitted by the loudspeaker is spread out through a larger volume as it travels away. This may not be an inverse square law since it depends upon the directionality of the speaker. So yes close to the speaker there is a much bigger disparity between the power of the direct and the reflected waves than close to the reflector.
Ye kinda big mistake!
quickly thinking back to this
Wave 1: ¦¦¦¦¦¦¦¦¦¦
Wave 2: ¦¦¦¦¦¦¦¦¦¦
Would this diagram be true if I plotted against time on the x-axis.
The space between each wavefront is the wavelength. It should take about double as long to complete a wavelength if we interfere constructively so the time taken along the x-axis between each wavefront should also be double?
This issue is often rushed over in textbooks.
For a traveling wave you can put either time or distance on the x-axis and draw a graph of some suitable quantity such as displacement or pressure against this.
So your graph describes how the wave varies in time at a fixed position in space
or
how the wave varies in space at a fixed instant in time.
Both graphs actually look pretty similar and are usually represented by a sinusoidal curve for sound mathematical reasons.
When you allow two waves to combine to form a standing wave a graph of your 'varying' property against time shows a straight line parallel to the x axis. The property does not vary with time or the wave is time independent.
A graph plotted against position shows the characteristic node/antinode sequence.
Understanding this goes back to your question about phase.
If we define the phase-difference between two spatial points as
'the time difference when our varying quantity reaches its maximum'
you can see this is zero for a standing wave.
All points in the wave reach their maximum simultaneously, at least between any two nodes.
Most textbooks omit to emphasise that the illustrations they draw for traveling waves plot time on the x axis, but when they illustrate standing waves they are plotting distance. They often place the two graphs in juxtaposition, when they are not really directly comparable.
If i were to address the issue using words I might then be able to imagine the graph.
What is going on in any constructive interferece is as follows: the amplitude of the two propagating waves combine to form maxima and minima. These new amplitudes, assuming the waves have the same amplitude will be double. This means that if we assume time along the x axis, it should take double as long to complete a stage in the wave than it would do with our propagating wave.
This means that if it took 0.1 second to complete each of our individual propagating waves, the length of time between each wave in our standing wave would be 0.2.
Obviousley there is not really a concept of time with a standing wave as the standing wave remains stationary so if we assume time as the distance between the beginning of one wave and the beginning of the next on both graphs, our standing wave would have a 'distance' of double the propgating wave
How's that as an explanation?
On a slight tangent:
http://s359.photobucket.com/albums/oo40/jsmith613/?action=view&current=Long.png
I am writing my notes for physics and came across this diagram telling me what the amplitude for a longitudinal wave is. From the equillibrium position to apparently the next point along (see where blue arrow points to and ends). Surley the displacement is the distance between an area of compression and an area of rarefaction divide by 2
OR does amplitude vary continuosley on a longitdinal wave. Is it actually the maximum displacement of each point on a wave from the equillibrium (in the diagram this is the distance between each line on the wave and the nearest equillibrium point)
Puzzling.
A standing wave has no period - it is time independent.
It does however have a wavelength, equal to twice the distance between adjacent nodes.
Only if the two waves are in phase and going in the same direction.
Can you name any real world waves that actually look like this?
What happens in the white space above and below your diagram?
Studiot said:
Puzzling.
this diagram was in my physics textbook but poorley explained. I don't know exactly what it is on about but know that I ought to know it - the book is officialy endorsed by edexcel
I would presume the what space in between the diagram was between the waves like in a slinkey
ignore the spaces above and below!
