How do one reduce the pressure?
  • Thread starter Thread starter hanson
    Pressure
The discussion centers on reducing air pressure from 4 bar to a few thousand pascals. A pressure regulator capable of reducing pressure to 0.1 bar is currently in use, but further reduction is required. Participants suggest exploring low-pressure regulators from manufacturers like Fischer, Fairchild, and Tescom, as well as using a throttle valve for specific applications. It is emphasized that a throttle valve does not inherently reduce pressure but can help manage flow rates in certain systems.
  • Understanding of pressure regulation and measurement units (bar, pascals)
  • Familiarity with pressure regulators and their specifications
  • Knowledge of throttle valves and their operational principles
  • Basic concepts of fluid dynamics in low-pressure systems
  • Research low-pressure regulators from Fischer and Fairchild
  • Investigate the use of throttle valves in pressure management
  • Explore the specifications and applications of Tescom regulators
  • Learn about pressure transducers suitable for sub-atmospheric measurements
Engineers, technicians, and anyone involved in pneumatic systems or pressure management looking to optimize low-pressure applications.
hanson
Hi all.
I have a air pressure supply of 4 bar and I need to reduce it to say a few thousands Pa.
What I have now is a pressure regulator that can reduce the pressure to 0.1 bar, but I need a even smaller pressure.
Is there any device that I can use?
I heard something called throttle valve? is it something I can use?
It reduces pressure by percentage or to a certain level?
Please kindly help. Thanks.
A throttling valve doesn't reduce pressure, it is simply a restriction in the line. It will serve the purpose of reducing pressure if the flow rate is constant, upstream pressure is constant, and there is some inherent feature in the system which compensates for minor variations in flow. Without knowing what your system looks like however, it's best not to speculate on whether or not a throttling valve would work.
There are many manufacturers of very low pressure regulators. I'd suggest looking into Fischer to start.
http://www.fisherregulators.com/
You should also do a search on www.globalspec.com based on your specific requirements to see if anything turns up.
Would running a couple of regulators in series do it?
No, it has to be designed for low pressure applications.
CS
Sorry, then, pal. I know nothing about this; I was just throwing in my 2 cents. Times like this, I really wish that I had an education.
He's only trying to reduce 50 psi to around 0.5 psi, so 2 regulators in series wouldn't really be necessary. I did a search on GlobalSpec and found many regulators that have adjustment ranges similar to the OP.
Depending on the fluid and the flowrates, there are indeed a lot of vendors that make applicable regulators. If it is a relatively low airflow requirement (when compared to large industrial applications), look at someone like Fairchild regulators or, for a more expensive but very nice regulator, look at Tescom.
Actually a throttle valve may work if you need to fill a vessel up to a specific pressure and the regulators output pressure is to high you can slow the fill rate down and more accurately fill your application. you will need a separate pressure transducer downstream of the throttle valve probably about 0-100 torr. The fact that you need sub-atmospheric pressures makes me believe you are probably not dealing with a continuous flow device.
http://www.swagelok.com/search/find_products_home.aspx?SEARCH=/id-10000277/type-1" makes good products just don't use the brass ones!
also take look to parker products. similar to swagelok
Rick
  • · Replies 29 ·
  • · Replies 17 ·
26K
