How Do the Laws of Motion Apply to a Block and Wedge System?
The discussion revolves around the application of the laws of motion to a block and wedge system, specifically analyzing the interactions and forces involved when one block impacts another in a pulley setup.
  • Participants explore the sequence of events in the system, questioning which block impacts first and the role of angles and forces involved. There are discussions about using energy equations versus force equations, and the potential need for integration.
Participants are actively engaging with each other's ideas, offering suggestions and clarifications. Some guidance has been provided regarding the use of energy equations and the assumptions about the pulley, but no consensus has been reached on the approach to solving the problem.
There are constraints regarding the parameters of the problem, such as the assumption of massless pulleys and the absence of friction. Participants are also clarifying the variables involved, including masses and distances.
draotic
Given in the pic .. .
F=mg
i think block 2 hitting wedge will take place 1st as the direction of displacement of B1 is perpendicular to 'g' .. .
but i don't think that's a logical answer
please answer and explain why
hi draotic! :wink:
call the displacement "x" and the angle "θ" …
what equations do you get? :smile:
sorry , i didnt quite get it .. .
which angle are we concerned about?
the angle the right-hand part of the string makes with the horizontal at any particular time :wink:
well the angle will vary from 0 to pi/2 , so are we going to involve integration ?
Block#2 needs the highest force up at vertically down, weight plus centripetal force before continuing to hit the wedge.
Thus block#1 must hit the pulley first before bigger block can continue the circular motion.
hi draotic! :smile:
(just got up :zzz:)
in problems like this, always try an energy equation first (which will avoid integration)
if that doesn't work, use a force equation (which will) :smile:
thanks tiny-tim and azizlwl for helping me out ..
azizlwl's reason seems quite right to me..
in B1 , only tension is involved ( ignoring kinetic friction ) and in B2 , we must have tension + centripetal force . .
so B1 must hit pulley first..
are all the parameters such as masses, distances from pulley variable?
masses are same , no friction anywhere , no MI of pulley
draotic said:
… no MI of pulley
you can assume the pulley is massless
(alternatively, just add its "rolling mass" (I/r2) to the mass of the first block)
  • · Replies 92 ·
10K
