How Do You Apply Noether Normalization to a Polynomial Ring Ideal?
  • Context: Graduate
  • Thread starter Thread starter gurilupi
14 replies · 3K views
gurilupi
Suppose ##I \subseteq k[X_{1}, X_{2}, X_{3}, X_{4}]## be the ideal generated by the maximal minors of the ##2 \times 3## matrix
$$\begin{pmatrix}
X_1 & X_2 & X_3\\
X_2 & X_3 & X_4
\end{pmatrix}.$$
I have to find a Noether normalization ##k[Y_1, Y_2, Y_3, Y_4] \subseteq k[X_1, X_2, X_3, X_4]## with ##I \cap k[Y_1, Y_2, Y_3, Y_4] = (Y_1, \ldots, Y_r)## for a suitable ##r##.
I've done: The maximal minors are the determinant(s) of the largest submatrices, i.e. in this case all ##2 \times 2## submatrices which then are (by deleting a column): ##\begin{pmatrix}
X_1 & X_2\\
X_2 & X_3
\end{pmatrix}, \begin{pmatrix}
X_1 & X_3\\
X_2 & X_4
X_2 & X_3\\
X_3 & X_4
\end{pmatrix}.## Then, taking determinants we get ##I = (X_1 X_3 - X_{2}^{2}, X_1 X_4 - X_3 X_2, X_2 X_4 - X_{3}^{2})##.
The next step would be to use the constructive proof of Noether's Normalization Lemma. However, I can't seem to understand the entire procedure of that proof and how to apply it to this problem. Perhaps if someone can illustrate this process, then I will better understand it after seeing it done.
The proof I have uses an induction. The following lemma seems crucial:
Let ##F\in k[X_1,\ldots,X_n]-\{0\}##. Then there is a substitution ##X_i=Y_i+X_n^{r_i}## for ##i=1,\ldots,n-1## and suited ##r_i## such that
F=aX_n^m+\rho_1 X_n^{m-1}+\ldots+\rho_m \quad (a\in k-\{0\},\rho_i\in k[Y_1,\ldots,Y_{n-1}])
The ##Y_i## are all inductively constructed according to this lemma.
The best approach is probably to run through the proof step by step for the given example.
Thanks for the answer. The proof of Nother's Normalization Lemma that I have also uses induction. The issue is that the hypothesis assumes a finitely generated algebra ##A##. So what is my finitely generated algebra and what are the generators?
fresh_42 said:
Kunz? It's difficult to talk about a technical proof with two different sources.
No, it's from Atiyah & Macdonald Introduction to commutative algebra.
That's not an issue since in the course we are assuming our field to be algebraically closed, i.e. infinite. Thus for the purpose of the problem statement we do have that ##k## is infinite. The issue that I have here is that I never seen the actual process of Noether normalization in practice. If the details are not too lengthy, perhaps you can write them out? I suspect that the computations are quite algorithmic and once one sees the process, then it becomes quite easy to replicate.
Edit: BTW, Atiyah also assume ##k## infinite. For finite ##k## one needs a different proof.
Your ##k##-algebra is your ideal ##I##. You have listed its generators. Do you see a polynomial relation between the generators?
No, I don't see a polynomial relation between the generators. I suppose you mean that we can somehow remove some indeterminants by substitution?
##(Y+X_1)\cdot\ldots\cdot(Y+X_n) =\sum_{k=0}^n \sigma_k(\mathbf{X})Y^{n-k} ## with ##\sigma_k(\mathbf{X})=\sigma_k(X_1,\ldots,X_n)=
\sum_{1\leq j_1<\ldots <j_k\leq n}X_{j_1}X_{j_2}\ldots X_{j_k}## could help.
Thanks for the link but I am uncertain where to even start the normalization process. The proof you linked says: induct on the number of generators of the ##k##-algebra. So in our case on the three generators of the ideal. Then, you pick one generator, say the first and check whether ##I = k[X_1 X_3 -X_{2}^{2}]## and whether the generator is transcendental. I suppose it’s algebraic and thus must have a minimal polynomial, say ##f##. Then, ##I \cong k[X_1, X_2, X_3, X_4] / (f)##.
And this is where my understanding breaks down; the next step assumes ##I = k[c_1, c_2, c_3, c_4]##, where the ##c_i## are the generators. How is the ideal the polynomial ring in the four variables ##c_i##?
In post #1, I don't even understand your second sentence. What is the definition of "a noether normalization"? And I would think your k algebra is the quotient of k[x1,..,x4] by your ideal I. (I itself is not a k algebra, in the usual sense, since it does not contain k.) But when I even talk about a noether normalization, I am always given a k algebra A to begin with. The fact that in post #3 you yourself ask what the k algebra is, suggests to me that you do not understand what you are being asked to do, which of course you admit. But could you just quote the problem you are given for us word for word?
Noether's normalization theorem is the process of decomposing a finitely generated algebra extension of k into two stages. one which is purely transcendental, followed by one which is integral. You cannot begin until you determine what the k algebra is that is given. This must be part of the data given in the problem.Presumably the f.g. k algebra is the quotient algebra A = k[X]/I. Then you want to find a sub algebra B which is isomorphic to a polynomial algebra, and such that A is integral over B.
Now one way to do this would be to find a sub algebra C of k[X], which is also a polynomial algebra in 4 variables Yj over k, and such that two things are true:
1) I intersect C = J is the ideal of C generated by some of the variables Yj;
so that the quotient B = C/J is again a polynomial k algebra;
2) and such that the extension A over B is module finite, hence integral.
I.e. your original given f.g. k algebra is presumably A = k[X]/I, and your sub algebra is B = k[Y]/J = C/J. By definition of J, the injection C-->k[X], induces an injection of B = C/J -->A.
Then A is finite over B and B is a polynomial algebra. So by the way your problem is set up, "all" you need is a polynomial sub algebra C = k[Y1,Y2,Y3,Y4] of k[X1,...,X4], with the Y's algebraically independent, and meeting I in an ideal J generated by some of the Yj, and such that A is finite over B = C/J.
I doubt if the general proof of the normalization theorem need be applied, since this is a concrete example, but it might help. Forgive me, as I have not really thought about your problem. (Does this belong in the homework section?) Were you told as a hint to use the "constructive proof of noether normalization"? were you given a reference for that "constructive proof"?
but anyway, if this interpretation is correct, then of course X1,...,X4 are your original generators for k[X] hence also for A = k[X]/I.
