How Do You Calculate Angular Acceleration from Tangential Acceleration?
14 replies · 12K views · last reply
makeAwish
Disk rotating problem. urgent, help pls..
A disk of radius 30.0cm is free to turn about an axle perpendicular to it through its center. It has very thin but strong string wrapped around its rim, and the string is attached to a ball that is pulled tangentially away from the rim of the disk. The pull increases in magnitude and produces an acceleration of the ball that obeys the equation a(t) = At , where t is in seconds and A is a constant. The cylinder starts from rest, and at the end of the third second, the ball's acceleration is 1.50 m/s^2.
a. Express the angular acceleration of the disk as a function of time.
b. How much time after the disk has begun to turn does it reach an angular speed of 17.5 rad/s?
c. Through what angle has the disk turned just as it reaches 17.5 rad/s?
The attempt at a solution
I have found A to be 0.500m/s^3.
but i duno how to do part a.
can help me pls?
thanks!
  • Diagram of a disk with a dot at its center, a string leaving its rim tangentially to a small ball, and a red arrow labelled Pull pointing right from the ball.
i tried applying angular acceleration, alpha = r/a where a is tangential acceleration. and i get 0.3/(0.5t)
the answer shld be in (rad/s^3)t units. and is independent on t..
Hi janettaywx! :smile:
(have an alpha: α :wink:)
No, A = 0.500m/s
No, look at the dimensions …
angular acceleration (α) is in rad/s2,
and ordinary acceleration (a) is in m/s2,
and r is in m,
so a = rα, and α = a/r :smile:
hahah. thanks for the alpha.
hmm. but i tot A is accel divide by time.. so its units is rad/s³?
so α = 0.5t/0.3 ?
hmm.. it shld be indpt of t.. what shld i do next?
so α = 0.5t/0.3 ?
sorry, I misread it … you're right, it is m/s3 :redface:
No, α = 0.5t/0.3 is ok … it should be a function of t :smile:
(because a = At, and α = a/r, so α = At/r :wink:)
hmm. say i want to convert it to radians, is this how we convert?
1rev -> 2∏ rad
1 rev = 2∏r = 2∏(0.3m)
so 2∏(0.3m) = 2∏ rad
0.3m -> 1 rad
and 1m -> (1/0.3)rad
den 0.5 m/s^3 = 0.5*(1/0.3) rad/s^3?
actually, from my qns here, they sae we shld get an answer indpt of t. but i don't rly noe why cos' it is a function of t...
(why ∏? everyone uses π :wink:)
No, it's already in radians …
the radian is defined specially so that α = a/r (or ω = v/r) works without adjustment. :smile:
but how u do 2nd part?? to find the time.
i tried taking time = angular speed / angular accel = 10.5s
but wrong..
You have angular acceleration as a function of time …
inegrate it to get angular speed as a function of time :wink:
hi!
means i will get (1.67t^2) / 2 = 17.5
so t = 4.58s?
so t = 4.58s?
Looks good :smile:
