How Do You Calculate Change in Kinetic Energy and Momentum for a Turning Loader?
The problem involves a 15,000 kg loader changing direction from traveling east at 20 km/h to south at 25 km/h. Participants are tasked with calculating the change in kinetic energy and linear momentum during this maneuver.
  • Mixed
  • Participants discuss the application of formulas for kinetic energy and momentum, with some expressing confusion about the vector nature of momentum. There are attempts to clarify how to handle the change in direction and the need to separate vectors into components.
Some participants have provided hints regarding the vector nature of momentum and suggested using graphical methods or components to approach the problem. There is acknowledgment of the need to consider both magnitude and direction in the calculations, but no consensus has been reached on the exact method to proceed.
Participants note the importance of understanding vector subtraction and the heat-to-tail method for resolving the problem, indicating that the original poster may have overlooked these aspects in their calculations.
MPat
A 15 000kg loader traveling east at 20km/h turns south and travels at 25km/h. Calculate the change in the loader's
a) kinetic energy
b) linear momentum
ΔKE= 1/2mvf^2 –1/2mvi^2
Δp= mv2 –mv1
m= 15000
vi = 20km/h = 5.56m/s
vf= 25km/h = 6.94m/s
[/B]
Part A I think I got.
Part B is where I am confused.
I am using Δp= mv2 –mv1
I substitute the numbers in
Δp= 15000*6.94 -15000*5.56
The magnitude of Δp that I arrive at is equal to 20 700...is that correct?
Also, when I am trying to find the change in direction when subtracting vectors you simply add the opposite direction. so rather than using east, i add my vector pointing south and add the initial vector but pointing west?
I then use this to calculate the angle for the direction. Is this right?
I tried to add an image to show you my diagram...but can't seem to figure out how!
Thanks in advance!
hint: momentum is a vector, and so is velocity
... so ##\Delta \vec p = \vec p_f - \vec p_i = m(\vec v_2-\vec v_1)##
... try subtracting the vectors by the heat-to-tail method.
But notice: you are not asked to find the magnitude of the change in momentum.
Thank you!
I think I got it, it's essentially the hypotenuse formed by the triangle...my numbers weren't adding up because I was forgetting that I had to separate the vectors into components, N-S and E-W.
MPat said:
Thank you!
Sometimes it's usful to look at vectors graphically, but you can also look at vectors as pairs (x, y) or triplets (x, y, z). In this case, you have:
Initial velocity ##= (u_x, u_y)##
Final velocity ##= (v_x, v_y)##
That might be an easier way to calculate the change in velocity and momentum in this case.
