How Do You Calculate Changes in Gravitational Force and Weight?
12 replies · 3K views
Neek 007
(These are problems I got wrong on a test)
1. How far above the Earth's surface will a person's weight be reduced to half its value at the surface?
2. A 4kg ball and a 2 kg ball are positioned so that their centers are 40 cm apart. With what force do they attract each other?
1. rE=6380km=6.38*106m
me=5.98*1024kg
g=(Gm)/r2
G=6.67*10-11Nm2/kg2 where G is universal gravitation
2. G=6.67*10-11Nm2/kg2 where G is universal gravitation
F=(Gm1m2)/r2
1. In problem 1 I know that in order for a mass to be half of what it is on Earth's surface, g must be half, so g=9.8m/s2 on Earth's surface, therefore g=4.9m/s2 at r.
What I did was use for formula g=(Gm)/r2 and solve for r. I think for m though, i used 25. For what reason, i don't know. I got the question wrong, so that's not the right method.
2. For problem 2, I used the F=(Gm1m2)/r2 and solved for F, the force. I ended up getting 1.339*10-12. I thought I did this right, but obviously not.
I need some direction into where to correctly start.
me=5.98*1024kg
g=(Gm)/r2
F=(Gm1m2)/r2
For problem 1:
In that equation, M is the mass of the Earth.
For problem 2:
You're method is fine. You must have made a calculation error. What numbers did you plug in for r, m1, and m2?
G01 said:
For problem 1:
Also, they say they want the height above the Earth's surface, not the radius.
You might have approached the problem in terms of ratios. Lot's of things cancel when you do these things as ratios!
g = G*M/Re^2
g/2 = G*M/(Re + h)^2
take the ratio (g/2)/g = 1/2 = ...
solve for h
G01 said:
For problem 1:
For problem 2:
for r i used 20. m1=2 m2=4
unless the radius is really 40, then i don't see where i messed up.
i got 1.334x10-12N
i got 1.334x10-12N
Units. Always check your units. The separation is specified in cm. 40cm is not the same as 40 meters.
G01 said:
For problem 1:
I think i have the right answer now, of
9*106 by √(GmE)/g
g being 4.9 m/s2
there is my problem. I should have seen that.
i should have gotten 1.334*10^-6
9*106 by √(GmE)/g
g being 4.9 m/s2
Is that the radial distance or the distance above the surface of the Earth?
They asked for the latter, no?
i think for number 2 the mistake was r should be changed to meters
that is the distance above Earth's surface, without the radius of Earth added on.
So let's check your result.
a = G*Me/(Re + 9 x 10^6m)^2
= (6.67 x 10^-11)*(5.98 x 10^24)/(6380 x 10^3 + 9 x 10^6)^2
= 1.56 m/s^2
= 1.56 m/s^2
how does the acceleration tell me if my answer is right or wrong?
oh i see, its the formula for gravity. it should equal 4.9 ms/^2
