How Do You Calculate Changes in PSI and Temperature from Volume Compression?
  • Thread starter Thread starter A Atwood
    Compression Psi
This discussion focuses on calculating changes in pressure (psi) and temperature resulting from volume compression in an internal combustion engine scenario. The key formulas identified are P2 = P1 (V1/V2) ^ y for pressure change and T2 = T1 (V1/V2) ^ (y-1) for temperature change, where y is approximately 1.4 for air. The initial conditions include a starting pressure of 14.7 psi and a temperature of 70°F (294 K), leading to calculated values of 369 psi and 896°F after a 10:1 compression ratio. The discussion emphasizes the importance of understanding adiabatic processes and the complexities involved in real engine conditions.
  • Understanding of the Ideal Gas Law (PV = nRT)
  • Familiarity with adiabatic processes in thermodynamics
  • Knowledge of compression ratios in internal combustion engines
  • Basic principles of thermodynamics, including temperature and pressure relationships
  • Research the effects of different gases on the value of gamma in adiabatic processes
  • Explore the implications of volumetric efficiency on engine performance
  • Study the relationship between temperature and pressure in real-world engine conditions
  • Learn about heat transfer dynamics during the compression and expansion strokes in engines
Engine builders, automotive engineers, thermodynamics students, and anyone interested in optimizing engine performance through an understanding of pressure and temperature changes during compression.
A Atwood
Trying to calculate changes in psi and temperature with a known change of volume.
One cubic foot of air(14.7 psi) compressed to one tenth its original volume. 10:1 compression ratio.
Starting temp=70° F or 294° K
Don't know the equation. That is the problem. I am really looking for the correct formula so that I can apply it to my engine building. It helps with boost and compression ratios.
The formula you want is
PV = nRT
n is the amountof gas (number of moles) and R is a constant depending on your units.
But if you don't change the amount of gas you can think of this as
PV/T = constant
The gas is a fixed amount. Trapped volume in the engine world.
Does the constant have a known value. Would you mind walking me through to find the solution.
Are you looking at an IC engine situation? If so, you want an adiabatic compression description for which
PV^gamma = const
If you reduce the volume by 10 then you increase the pressure by 10 - assuming the temperature stays the same,
In a real situation it's more complicated, the temperature will also go up (like a bike pump getting hot) and then heat will be lost (to the radiator) which will reduce the pressure
DrD is right. In PV=nRT there is one too many unknows. You need to specify the conditions of compression: Both constant termperature is common. And the case where no heat is transfered.
I don't recall the exponent, gamma. However, we do know that air is primarily diatomic molecules, which determines gamma when no heat is transferred to the environment, right?
We need to hear from A Atwood as to what his problem really is before we can make any headway on this matter.
I appreciate the help. What I am calculating, is the psi and temp changes that go on inside of a running engine.
I found a couple of formulas on your site by doing some searching. I believe they are the correct formuls that I need.
P2 = P1 (V1/V2) ^y
for pressure change, and
T2 = T1 (V1/V2) ^{(y-1)}
for temp change.
Y=1.4
No heat gained or lost from surrounding combustion chamber(adiabatic).
For a 10:1 engine working at 100% volumetric efficiency, and starting temp of 70° F. I come up with:
Psi=369
Temp=896
Correct??
The adiabatic compression model works well for the compression stroke, up to the point where combustion begins. At that point, both temperature and pressure rise by some other, undefined rule. Following shortly after TDC, there is an adiabatic expansion phase (the power stroke) until the valves open and the cylinder pressure drops very rapidly at that point.
The value of gamma depends on what you are compressing. Your 1.4 value is about right for air, but I have seen values as low as 1.35 used. It is hard to predict because what you have is a mixture, not a pure gas (at least that is true in most cases), so the gas properties depend on the mixture and are hard to predict by chemistry.
The reason for the adiabatic model is that heat transfer is a relatively slow process, and in a single crank cycle, there simply is not time for significant heat transfer to take place.
PS: your pressure value looks OK, assuming you start with a cylinder pressure at 14.7 psia at the beginning of the stroke.
Thanks Dr. D.
I am only interested in the pressure and temp just prior to ignition @ TDC(top dead center).
Reason is, knowing these values, helps in determining if the pressure and temperature are significant enough to create detonating or pre-ignition. Octane of the fuel requirements as well.
Is my temp value correct?
ARN
A Atwood said:
Psi=369
Temp=896
Correct??
disclaimer: I'm an electrical engineer, and am just self-learning the thermo stuff
i agree on the pressure, though wikipedia has 323 psi (22:1 ratio). I've posted that i disagree and that they don't have any references. i'd love to know if we're right or wp ...
http://en.wikipedia.org/wiki/Compression_ratio#Compression_ratio_versus_overall_pressure_ratio
looks like you used 300 C for your calc of temp. 70oF is actually 294 C. but assuming that's what you did, i agree
For the temp calcs, I had to convert to kelvin, then back to F. All temp calcs must be based off of absolute.
ARN
s/C/K/g
sorry for the type, but the point still stands ... 70oF --> 294 K
Tc = To * rc^.4
(300*10^.4 - 273.15) *9/5 + 32 = 896.75 oF
(294*10^.4 - 273.15) *9/5 + 32 = 869.62 oF
looks like you used 300K instead of 294K. or did you do something different ?
Maybe I'm just a little dyslexic, I tried re-calculating and came up with the same result as you.
70°F with 10.0:1 compression -869°F.
Not sure what I did wrong the first time.
Thanks for the correction.
ARN
I thought it would be easy Using PV=nRT I get P1V1=nRT1 P2V2=nRT2 (the n and R don't change if you compress or heat it). I rearrange and get V1=nRT1/P1 also T2=P2V2/nR. I also know that V1=(1/10)V2 by combining and canceling I get T2=P2T1/P1. T1=294 P1=14.7. so T2=P2*(294/14.7)
Long story short I ended up with a relationship between T2 and P2, but there are still too many variables.
Welcome to PF.
homernukem said:
... there are still too many variables.
You have either too many variables, or not enough equations. Try using one of these:
P2 = P1 (V1/V2) ^y
for temp change.
Y=1.4
  • · Replies 48 ·
  • · Replies 20 ·
  • · Replies 33 ·
