How Do You Calculate Forces in a Two-Mass System on an Accelerating Scale-Pan?
  • Thread starter Thread starter bubakazouba
    Lift Mechanics
The discussion focuses on calculating forces in a two-mass system involving a scale-pan with masses A (400g) and B (600g) under an upward acceleration of 0.5 m/s². The tension in the string is calculated as 10.3 N, derived from the equation Tension - (0.4 x 9.8 + 0.6 x 9.8) = 0.4 x 0.5 + 0.6 x 0.5. The force exerted on mass B by mass A is determined to be 4.12 N, which accounts for both the weight of mass A and the upward acceleration, illustrating the application of Newton's laws in dynamic systems.
  • Understanding of Newton's laws of motion
  • Familiarity with free body diagrams
  • Basic knowledge of force calculations (F=ma)
  • Concept of tension in strings and acceleration
  • Study the application of Newton's second law in multi-body systems
  • Learn how to draw and analyze free body diagrams for complex systems
  • Explore the concept of contact forces and their implications in dynamics
  • Investigate the effects of acceleration on forces in various physical scenarios
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors looking to enhance their understanding of force calculations in dynamic systems.
bubakazouba
a light scale pan is attatched to a vertical inextensible sring. The scale-pan carries two masses A and B. The mass of A is 400g and the mass of B is 600g. A rests on top of B, as shown in the diagram.
The scale-pan is raised verticaly, using the string with acceleration 0.5 m/s².
a)find the tension in the string.
b)find the force exerted on mass B by mass A
c)find the force exerted on mass B by the scale-pan.
visual representation of the problem http://i1269.photobucket.com/albums/jj597/bubakazouba/test_zps62ac1992.png
F=ma
g=9.8 m/s²
I got a) correct, I just said
Tension-(0.4x9.8 +0.6x9.8)=0.4x0.5+0.6x0.5
Tension-9.8=0.5
tension =9.8+0.5=10.3N
I think the answer is mg its the weight, because its the only downward force on A so it should be 0.4x9.8=3.92, but its not right.
What am i missing here?
Thanks in advance
hi bubakazouba! :smile:
I think the answer is mg its the weight, because its the only downward force on A so it should be 0.4x9.8=3.92 …
what about the acceleration? :wink:
what about it?
bubakazouba said:
what about it?
you haven't used it
why should I use it?
i] it's in the question
ii] F = ma :wink:
I don't get it why should I use any equation, isn't it obvious the only force that acts on B is the weight, mg
that's the LHS of the equation
what about the RHS?​
what equation?
I feel so stupid right now :'(
Draw a free body diagram on A, showing the forces acting on it. Write a force balance on A, recognizing that A is accelerating upward at a rate of 0.5 m/s2.
ok I got a force 4.12N upwards what does that mean?
That's the contact force exerted by mass B on mass A. Now, from Newton's third law of action-reaction, what is the contact force that mass A exerts on mass B?
4.12?
but why, why isn't it the weight?
4.12?
bubakazouba said:
4.12?
Because mass A is accelerating upward, and so mass B has to exert enough upward contact force not only to support the weight of mass A (which would be the case if A were in equilibrium), but also to accelerate it. Also, by Newton's third law, the contact force A exerts on B is equal in magnitude and opposite in direction to the contact force B exerts on A.
