How Do You Calculate NaCH3COO Concentration and Predict pH at Equivalence Point?
  • Thread starter Thread starter cvc121
    Titration
The discussion revolves around a homework problem involving the calculation of the concentration of sodium acetate (NaCH3COO) and predicting the pH at the equivalence point of a titration between hydrochloric acid (HCl) and sodium acetate. Participants explore the theoretical aspects of the titration process, including the relationship between moles of titrant and analyte, and the implications of the equivalence point on pH.
  • Homework-related
  • Post 1 outlines a method for calculating the concentration of NaCH3COO based on the moles of HCl used at the equivalence point and proposes a theoretical pH calculation using the pKa of acetic acid.
  • Post 2 challenges the validity of the concentration calculation, suggesting that the question likely asks for the initial concentration of NaCH3COO rather than its concentration at the endpoint.
  • Post 3 seeks clarification on whether the initial concentration can be determined from the volume of NaCH3COO used, proposing a calculation based on that volume.
  • Post 4 expresses agreement with the previous post's reasoning.
  • Post 5 questions the clarity of the original problem statement and suggests that the calculations may not align with the intended question, indicating that the calculation might reflect the pH of acetic acid instead of the titration process.
Participants express disagreement regarding the interpretation of the homework question, with some suggesting it is unclear or poorly phrased. There is no consensus on how to approach the calculations, particularly regarding whether to use the total volume at the equivalence point or the initial volume of NaCH3COO.
Participants note potential limitations in the problem statement's clarity and the assumptions made in the calculations, particularly regarding the nature of the titration and the role of sodium acetate.
cvc121
a) Determine the concentration of NaCH3COO. The volume of HCl used to reach the equivalence point is 25.05 mL, the concentration of HCl is 0.10 M, and the volume of NaCH3COO solution used is 10.0 mL.
b) Using the initial concentrations of NaCH3COO and HCl, and a reliable literature value for the pKb for NaCH3COO or PKa for CH3COOH, predict the theoretical pH of the equivalence point.
Here is my reasoning and calculations:
a)
The equivalence point is the point in the titration when the number of moles of a standard solution (titrant) is equal to the number of moles of a solution of unknown concentration (analyte).
Therefore, at the equivalence point:
ntitrant = nanalyte
nHCl = nNaCH3COO
moles of HCl = (concentration)(volume)
moles of HCl = (0.10 M)(0.02505 L)
moles of HCl = 2.5 x 10-3 mol
moles of HCl = moles of NaCH3COO = 2.5 x 10-3 molConcentration of NaCH3COO = moles / total volume
Concentration of NaCH3COO = 2.5 x 10-3 mol / (0.01 L + 0.02505 L)
Concentration of NaCH3COO = 0.07 M
b)
A reliable literature value for the pKa for acetic acid is 4.756.
pKa = -log Ka
Ka = 10-pKa
Ka = 10-4.756
Ka = 1.754 x 10-5
At the equivalence point of the titration of a weak base with a strong acid, the general reaction H3O+ (aq) + B (aq) ---> BH+ (aq) + H2O (l) has gone approximately to completion. Therefore, approximately all sodium acetate (NaCH3COO) will be converted to its conjugate acid, acetic acid (CH3COOH), in a 1:1 molar ratio.
Ka = [CH3COO-][H3O+] / [CH3COOH]
1.754 x 10-5 = x2 / (0.07 M – x)
Ka is very small. Therefore, the x value in the denominator is negligible and can be omitted.
1.754 x 10-5 = x2 / 0.07 M
x2 = (1.754 x 10-5 )(0.07 M)
x2 = 1.228 x 10-6 M
x = 1.108 x 10-3 M
[H3O+] = x = 1.108 x 10-3 M
Validity check:
(1.108 x 10-3 M / 0.07 M )(100%) = 1.58%
Theoretical pH = -log[H3O+]
Theoretical pH = -log[1.108 x 10-3]
Theoretical pH = 2.96
Could anyone verify my reasoning and calculations? Thanks. All help is very much appreciated.
There is no CH3COONa at the endpoint so your calculation of concentration (using total volume at the endpoint) doesn't make much sense. Question most likely asks for the initial CH3COONa concentration.
b looks reasonalby accurate.
Question is a bit idiotic to be honest. Good luck detecting the end point in this titration (not your fault though).
Thank you for your response. Assuming that the question is asking for the initial concentration of CH3COONa, does the question provide enough information to solve for this? Would I simply use the volume of CH3COONa used instead of the total volume?
Concentration of NaCH3COO = 2.5 x 10-3 mol / 0.01 L = 0.25 M?
Looks OK.
I concur with BoreK that the question does not make a lot of sense. Are you sure you have copied it and any background out exactly? One titrates an acid with a base or vice versa;, one does not titrate a salt which is what sodium acetate is.
Your calculation in #1 is just giving you the pH of 0.07 M acetic acid.
Maybe that was not the question but until we know exactly what it was it is not really worth further thought
