How Do You Calculate Resistance and Current in a Carbon Block Using Ohm's Law?
The discussion focuses on calculating the resistance and current in a carbon block using Ohm's Law. The block measures 3 cm in length with a square cross-section of 0.5 cm by 0.5 cm, and a potential difference of 8.4V is applied. The resistance is calculated using the formula R = ρL/A, where ρ represents resistivity. Participants clarified the block's shape as a cuboid, aiding in visualizing the problem for accurate calculations.
  • Understanding of Ohm's Law
  • Familiarity with the formula R = ρL/A
  • Knowledge of resistivity concepts
  • Basic geometry of cuboids
  • Research the resistivity values for carbon materials
  • Learn how to calculate current using I = V/R
  • Explore the implications of different cross-sectional areas on resistance
  • Study the effects of temperature on resistivity in conductors
Students in physics or electrical engineering, educators teaching Ohm's Law, and anyone interested in practical applications of electrical resistance calculations.
LeakyFrog
A block of carbon is 3cm long and has a square cross section whose sides are .5cm long. A potential difference of 8.4V maintained across its length.
a)What is the resistance of the block?
b)What is the current in this resistor?
R=pL/A
where p is resistivity
I'm fairly certain i can solve this problem right quick if I could understand what exactly the block looked like. The description just doesn't make sense to me. I'm not sure if you can draw pictures on this or not but a picture would be helpful if someone can make one. Thanks.
From what I've read the block is a cuboid. Imagine a square that's 0.5cm by 0.5cm, now stretch that back in the third dimension by 3cm, and Bob's your uncle. A similar shape to a packet of gum.
thanks dude (or dudette)! helped a bunch!
No worries mate.
  • · Replies 16 ·
  • · Replies 21 ·
