How Do You Calculate the Charge and Energy in a Mixed Capacitor Circuit?
  • Thread starter Thread starter Laxman2974
    Capacitance
The discussion revolves around a capacitor circuit involving a potential difference of 100 V applied across capacitors with values C1 = 11.0 µF, C2 = 7.00 µF, and C3 = 3.00 µF. Participants are tasked with finding the charge on each capacitor, the potential difference across each, and the stored energy.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the arrangement of capacitors in series and parallel, with some attempting to calculate the equivalent capacitance before applying the voltage. Questions arise about the correct formulas for charge and capacitance, particularly in series configurations.
Some participants have offered guidance on finding the equivalent capacitance and calculating total stored charge. There is an ongoing exploration of how to split charge between capacitors in series and parallel, with multiple interpretations of the circuit setup being discussed.
Participants express uncertainty about the formulas used and the need for clarity on how to approach the problem, particularly regarding the relationships between charge, voltage, and capacitance in series and parallel configurations.
Laxman2974
1. Homework Statement
a potential difference V = 100 V is applied across a capacitor arrangement with capacitances C1 = 11.0 µF, C2 = 7.00 µF, and C3 = 3.00 µF. Find the following values Charge on each capacitor, potential difference on each capacitor, and stored energy in Joules.
The circuit is set up with battery and then a mixed series and parallel. C1 and C2 are in a series on a branch and C3 is on a separate branch in parallel with both C1 and C2.2. Homework Equations
In a series I find charge with (1/c1 + 1/c2) = q/v looking for q. I plugged in (1/11 + 1/7) = q/100. SOlved and got a charge of 23.4 microCoulombs each on C1 and C2.
So now I am stuck I thought I solved the series first and then used that combine capacitance to find the charge on C3. Help
This is the response I got:
I would suggest finding the equivalent capacitance of all of them before applying voltage.
As I read your problem you have C1 and C2 in series with each other but taken together in parallel with C3. With the value of the effective capacitance you can calculate total stored charge in the system. Then maybe work backwards splitting the charge between the two branches could give you some insight?
How do I find equivalent capacitance for the system of circuits?
I don't believe that formula is correct.
If I'm visualizing the circuit correctly, I don't think you need to find the total capacitance of all three resistors. As soon as you find two of the values (C,Q,V) for a capacitor you can use C=Q/V to find the other one. Do you see how that helps with C3?
No-the only thing I can figure is that I needed to find the capacitance of 1 and 2 together because they are in a series. I thought I did this by C12=Q/V = 1/c1 + 1/c2. With this combine capacitance I can then find the charge.
But to find the combined capacitance in series, you add the reciprocals, and then take the reciprocal again.
You have [itex]C_{12}= Q/V[/itex] part right, where [tex]V[/tex] is the total voltage across the combinations of [itex]C_1[/itex] and [itex]C_2[/itex], but the other equation needs to be:
[tex] \frac{1}{C_{12}} = \frac{1}{C_1}+ \frac{1}{C_2}[/tex]
You then put the equations together and solve for the Q of C1 and C2.
Ok- so I solved for 1/c1 + 1/c2 = 233766.2338, plugged that into Q/V = 1/(1/Ceq) = 4.277e-4 to get the charge, is this charge on both capacitors or is it split over both.
To answer that question, remember that the capacitors [itex]C_1[/itex] and [itex]C_2[/itex] you're talking about are in series. Does that mean that the charge or the voltage are the same for [itex]C_1[/itex], [itex]C_2[/itex], and [itex]C_{\rm eq}[/itex]?
The charge is the same - the voltage across wach capacitor will differ
That sounds right to me. So you have found the charge on [itex]C_1[/itex] and [itex]C_2[/itex], which are both equal to the charge you found on [itex]C_{\rm eq}[/itex].
What about [itex]C_3[/itex]? What did you get?
Okay - let's go back to the begining, because I am messing up somewhere:
C1 = 11microF
C2 = 7microF
C3 = 3microF
Voltage across arrangement = 100V
--------------------- C123 = C12 + C3 C12 = 1/(1/C1+1/C2)
| | | C12 = 1/.233766microF
| C1 - | C12 = 4.2778microF
V | C3 -
| | | C123 = 4.2778microF + 3microF
| C2 - | C123 = 7.2778microF
I need to find charge on each capacitor, potential difference across each capacitor and stored energy.
I just figured out I don't need C123...since c12 and c3 are in parallel they experience the same voltage.
q12 = C12V = 428microC
and
q3 = C3V = 300microC
I think I got it now - I think I canfind the potential across each capacitor and the energy?
I'll reply if I can't Thanks alph
  • · Replies 27 ·
14K
