How Do You Calculate the Magnitude of the Sum of Two Vectors?
  • Thread starter Thread starter WPCareyDevil
    Magnitudes Vectors
The discussion focuses on calculating the magnitude of the sum of two vectors, specifically vector \(\vec{A}\) with a magnitude of 3.6 units and vector \(\vec{B}\) with a magnitude of 5.9 units, separated by a 45° angle. The correct approach involves determining the x and y components of both vectors using trigonometric functions, specifically sine and cosine. The final magnitude of the resultant vector is calculated using the formula \(\Delta V = \sqrt{V^2_x + V^2_y}\). The participants emphasize the importance of correctly identifying the components and applying vector addition accurately.
  • Understanding of vector components and trigonometric functions (sine and cosine).
  • Familiarity with the concept of vector addition in two dimensions.
  • Knowledge of the Pythagorean theorem as it applies to vector magnitudes.
  • Ability to solve right triangles, particularly 45/45/90 triangles.
  • Learn how to calculate vector components using trigonometric identities.
  • Study the process of vector addition in two-dimensional space.
  • Explore the application of the Pythagorean theorem in vector magnitude calculations.
  • Practice solving problems involving vectors at various angles to reinforce understanding.
Students studying physics or mathematics, particularly those focusing on vector analysis and trigonometry. This discussion is beneficial for anyone struggling with vector addition and component calculations.
WPCareyDevil
Vector \vec{A} has magnitude 3.6 units; vector\vec{B} has magnitude 5.9 units. The angle between A and B is 45°. What is the magnitude of \vec{A} + \vec{B}?
\DeltaV= \sqrt{V^2x +V^2y}
"SohCahToa"
I am really struggling with this for some reason. I know its just a SAS triangle.
Sin(45)=x/5.9 = opposite angle (y component, no?) =4.1719.
I tried using sqrt(4.1719^2 + 3.6^2)
where 3.6 is the x component and 4.1719 is the y component
=5.510
But, this is not correct. Basically all of my webassign problems are similar to this type, more or less complicated. Could you please point me in the right direction?
Thank you so very much for your time!
Edit: I searched but was unable to find a thread that helped. If you know of one, that would be appreciated also
Mathematically, that statement is nonsense.
What you mean is, if x is the y-component of B, then
sin(45) = x / 5.9
so
x = 5.9 sin(45) = 4.1719
Let's call it By instead.
Similarly, what is the x-component Bx of B?
Then do the vector addition:
(A + B) = [ Ax + Bx, Ay + By ]
and then calculate the magnitude using the formula you gave.
Thank you for the reply!
Ok, I now understand that I need to calculate the x and y components of each vector.
By=4.1719
Bx=[sin(45)=3.6/x]=2.5456
Ay=[sin(45)=x/3.6]=2.5456
A=[cos(45)=x/3.6]=2.5456
Therefore A=5.09117, B=6.7175
However, when I plug this into the equation I get an incorrect answer (8.4288).Can you make it a little more clear? Thank you so much for the help.
Ok, making progress here.I split each of the two vectors up as right triangles with HypA=3.6, HypB=5.9
Ax will =Ay
and Bx will = By, because they are 45/45/90 triangles.
Ay+Ax=5.0912
By+Bx=8.3486
But those two numbers do not yield the correct answer in the formula either (9.774473).
What am I doing wrong? I have gotten other answers on my homework correct.
Do I need to use the formula twice? Ie (ax, ay), and then (bx, by) then add? Just thinking out loud
22K
10K
