The discussion revolves around calculating the temperature at which water (H2O) molecules split into hydrogen and oxygen atoms. Participants explore theoretical and experimental approaches to determine this temperature, considering thermodynamic principles and quantum mechanics.
- Exploratory
- Technical explanation
- Experimental/applied
- One participant seeks a method to calculate the temperature at which the energy required to keep hydrogen and oxygen together exceeds that needed to separate them.
- Another participant suggests measuring the temperature of decomposition by heating the substance and checking for decomposition products.
- It is proposed that thermodynamic data could be used to calculate the equilibrium constant as a function of temperature, though this requires experimental data.
- A later reply discusses using enthalpy change (ΔH) and entropy change (ΔS) to calculate the temperature at which breaking apart water is as favorable as forming it, noting that this relies on the assumption that ΔH and ΔS do not change significantly with temperature.
- One participant expresses interest in predicting the dissociation temperature using quantum mechanics, while another mentions that dissociation at a given temperature is also influenced by factors like low pressure and concentration.
Participants express various approaches to the problem, but there is no consensus on a specific method or solution. Multiple competing views and uncertainties remain regarding the calculations and assumptions involved.
The discussion includes assumptions about the constancy of thermodynamic values over temperature ranges and the influence of external conditions like pressure and concentration on dissociation.
