How Do You Calculate the Time Ratio for Two Jumping Heights on a Trampoline?
  • Thread starter Thread starter ian_durrant
The problem involves two students, Anne and Joan, who are bouncing on a trampoline, with Anne reaching a height 2.61 times greater than Joan. The objective is to find the ratio of the time spent between bounces for each student, assuming free-fall motion.
  • Participants discuss the use of kinematic equations to relate height and time, with one participant noting an issue with obtaining negative time values. Questions arise regarding the frame of reference and the implications of negative results.
Participants are actively engaging with the problem, questioning the assumptions made about the frame of reference and discussing the implications of the negative time values. Some guidance has been offered regarding the ratio of time, suggesting that certain calculations may not be necessary.
There is an ongoing discussion about the choice of coordinate system and how it affects the calculations, particularly regarding the signs of displacement and acceleration. The original poster's approach to calculating time based on height is also under scrutiny.
ian_durrant
[SOLVED] Acceleration/Velocity Problem
Two students, Anne and Joan, are bouncing straight up and down on a trampoline. Anne bounces 2.61 times as high as Joan does. Assuming both are in free-fall, find the ratio of the time Anne spends between bounces to the time Joan spends.
y=V(0)t+ (1/2)gt^2
Ok I figured that if Anne is jumping 2.61 times as high as Joan, I could set y (the displacement) as 2.61 for Anne and 1 for Joan. However I plugged the numbers into the equation and ended up getting a negative answer for my time, which doesn't make sense. Here's my equations that I used:
Anne-
2.61=(1/2)(-9.8)t^2
-.53=t^2
Joan-
1=(1/2)(-9.8)t^2
-.204=t^2
I figured what I would do after i got the time is to multiple them both by 2 since I only calcuated them returning for the highest point to lowest point, then plugging them into a ratio. Any thoughts?
right method, and you won't have to multiple both by 2 since the ratio will cancel that out anyway
good point about the ratio, but I'm still confused why I'm going to have a negative number for t, or would this not matter anyways?
Hi...
You might want to think twice about your frame of reference. I work well positive as up and negative is down. But it looks like you work the same way as well since your acceleration is negative. That would mean that your initial location is higher than your final. No matter where you make your y=0...y(initial)>y(final). That is why you are getting a negative.
thanks for all the help everyone
  • · Replies 30 ·
  • · Replies 21 ·
12K
