How Do You Calculate Torque and Efficiency in a Three Phase Induction Motor?
The discussion revolves around calculating torque, efficiency, and losses in a three-phase induction motor based on given parameters such as current, power factor, voltage, and losses. The scope includes homework-related problem-solving and application of relevant equations.
  • Homework-related
  • One participant presents a homework problem involving a three-phase induction motor and expresses uncertainty about the formulas needed to calculate torque and efficiency.
  • Another participant suggests using the equation Power = Torque * angular velocity, noting the absence of the motor's synchronous speed as a critical piece of information.
  • Further replies emphasize the need for synchronous speed and suggest representing it algebraically if a numerical value is not provided.
  • There is a suggestion to assume a specific number of poles for the motor to derive synchronous speed, with a formula provided (Ns=120f/p).
  • One participant points out that the original poster may have moved on since the thread is over a year old.
Participants generally agree on the need for synchronous speed to solve the problem, but there is no consensus on how to proceed without it. Multiple approaches are suggested, but the discussion remains unresolved regarding the best method to calculate the required values.
Limitations include the lack of synchronous speed information and the need for assumptions regarding the number of poles in the motor. The discussion does not resolve these issues.
Student96
A three phase cage rotor induction motor running at full load draws a stator current of 60A at a power factor of 0.8 lagging from a 415v, 50Hz Supply. Under the conditions the stator loss is 3.6kW, the rotor loss is 1.3kw and percentage slip is 4.5%. If the shaft power output is 29.4kW, calculate the shaft output torque, efficiency & mechanical friction and windage loss.
Torque = Force * distance
At first i tried using the power output 29.4kw to try to work out the torque but then realized that its not used for force.
Now unfortunately this is were I'm stuck at, I really need help on this and I can't get my head around the question. I am uncertain of what formulas to use and would really appreciate it if someone could guide me and tell me which ones to use :confused:.
Hi Student96! http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
They don't tell you the motor's synchronous speed?
Does the textbook give you the answers?
Perhaps more relevant is..
and as NascentOxygen said they don't give you the angular velocity.
Thank you for replying NascentOxygen! , unfortunately it does not state synchronous speed and i haven't got a textbook containing the answer since its a homework sheet :frown:
In which case, to demonstrate that you really do understand the work, you could represent synchronous speed algebraically, e.g., Ns RPM, and work through the exercise based on that in place of a numerical value.
Alternatively, perhaps all of the induction motor exercises you have worked through in class have involved a particular synchronous speed, for convenience? If so, maybe you could assume that value for this exercise, too?
Have you asked other students in your class how they are going to answer this?
assume that the number of poles is 2 (or some other number) state this assumption the Ns=120f/p
Hi kevinj. :welcome:
You may not have noticed that the thread you responded to here is over 12 months old. Most likely the poster by now has moved on (one way or another). :smile:
... or some other even number.
