How Do You Derive the Marginal Distributions of a Uniformly Distributed Disc?
The discussion revolves around deriving the marginal distributions of a uniformly distributed disc, specifically focusing on the probability density function (pdf) and the double integral involved in the calculations. Participants are exploring the implications of uniformity in the context of the given pdf and the appropriate limits for integration.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the definition of uniform distribution and question whether the provided pdf is indeed uniform. There are attempts to set up double integrals for marginal distributions, with some participants expressing confusion over the limits of integration and the results obtained.
The discussion is active, with participants sharing their attempts and calculations. Some guidance has been offered regarding the definition of marginal distributions and the need to clarify the integration limits. Multiple interpretations of the problem are being explored, particularly concerning the uniformity of the distribution.
Participants are working under the constraints of homework rules, which may limit the information they can share. There is an ongoing debate about the correct setup for the double integral and the implications of the uniform distribution in this context.
lordslytherin
1. Homework Statement
Here is the link to the old thread, https://www.physicsforums.com/showthread.php?t=349730
i tried posting but it doesn't seem active. I don't understand how they get the second pdf as i tried it and got the first pdf. I also don't know how to do the double integral as what would the limits be?
2. Homework Equations
Limits for checking pdf
Pdf itself
3. The Attempt at a Solution
i got the same as rosh300 in the first attempt.
Any help would be appreciated
f_(r,theta)={1.5(r^2)/pi, for r E [0,1] and theta E [0,2pi]??
0 otherwise
by doing the double integral formula this gives 1 as required. However i don't know how to find the marginal distributions of X and Y
Open up any decent multivariable calculus textbook, or see here.
0 otherwise
What is the definition of uniform (in this context)? Does [itex]\frac{3}{2}\pi r^2[/itex] seem uniform to you?
Well, what is the definition of a marginal distribution? Apply that definition.
So it should be integral between 0 and 1 of the integral on (1/pi) between +and - (1-(x^2))^.5 dydx but when i worked this out the answer was 0.5 rather than 1.
No 3/2(pi)r^2 doesn't seem uniform but when i changed it to polar coordinates the double integral gave a value of 1.
Show the steps of your calculation.
Doesn't the problem ask for a uniform distribution?
firsly i did:
integral of (1/pi) dy evaluated between (1-(x^2))^0.5 and -(1-(x^2))^0.5 giving (2/pi)(1-(x^2)^0.5
then integral of (2/pi)(1-(x^2)^0.5 dx between 0 and 1 is (2/pi) x (pi/4) = 0.5
I see what you mean about the uniform part, i was just trying lots of methods to get it to work.
lordslytherin said:
then integral of (2/pi)(1-(x^2)^0.5 dx between 0 and 1[/color] is (2/pi) x (pi/4) = 0.5
Why are you only integrating from 0 to 1, y ranges from -1 to 1 for an entire unit circle (centered at the origin).
that's why you're a homework helper, damn that's annoying thanks very much. so the marginal distribution for y is f(y)= integral of (1/pi)dx between 1 and -1 which gives 2/pi
and the marginal distribtuion of x is f(x) =integral of (1/pi)dy between (1-(x^2)^0.5 and -(1-(x^2)^0.5= (2/pi)(1-(x^2))^0.5
so they are independent?
  • · Replies 87 ·
  • · Replies 19 ·
