How Do You Determine the Load Resistor Value for Maximum Power Dissipation?
25 replies · 5K views · last reply
chocolatecake
A constant voltage source V with internal resistance r is connected to a load resistor R. The dissipated power by the resistor R is P=RV^2/(R+r)^2. Show that the maximum power dissipated by the resistor R is achieved when R = r. The maximum of P with respect to R is achieved when dP/dR = 0.
[/B]
P = RV^2/(R+r)^2
[/B]
Well, I think that I need to find the absolute maximum. That means I need to find the first derivative, find the critical points, evaluate the equation at the critical points and find the absolute maximum. And somehow show that R = r.
To find the first derivative, I used the chain rule and came up with this:
f(g(x)) -> f'(g(x))g'(x)
P = RV^2/(R+r)^2 f = RV^2/x^2 g = R+r
f' = (2Vx - 2xRV^2)/x^4 g' = 0
P'= (2V(R+r) - 2(R+r)RV^2)/(R+r)^4
= (2V - 2RV^2)/(R+r)^3
(2V - 2RV^2)/(R+r)^3 = 0
I don't know if this is correct and I don't know how to go on from here. The denominator can't be zero because the derivative won't exist at those points. But if I set the nominator to zero, it doesn't really help me because there's no r, only R. What am I doing wrong?
All help is appreciated, thanks!
Welcome to the PF. :smile:
I don't think it's correct, because at least the units don't match. I also don't quite follow your approach at the derivative. Certainly your thoughts to take the derivative and set it equal to zero are correct...
Let me post my work in a couple of minutes to see if it helps...
(using LaTeX to post the math -- you can find the tutorial for LaTeX here: https://www.physicsforums.com/help/latexhelp/)
[tex]P(R) = R\frac{V^2}{(R+r)^2} = (RV^2)(R+r)^{-2}[/tex]
[tex]\frac{dP(R)}{dR} = (RV^2)(-2)(R+r)^{-3}(1) + (R+r)^{-2}(V^2) = 0[/tex]
(Distribute, simplify, simplify...)
[tex]-R^3-R^2r+Rr^2+r^3 =0[/tex]
Which you should be able to solve. By inspection, one solution is r=R:
[tex]-r^3-r^3+r^3+r^3= 0[/tex]
But maybe there are other solutions? :wink:
BTW, I've never liked the quotient rule for derivatives. I always prefer to convert the equation into a product, and apply that differentiation rule instead. It's simpler for my tiny brain... :smile:
Thank you so much for your help!
I thought that the derivative might be wrong. Thanks for the idea to convert the equation into a product. It's so much easier, I'm always going to do that from now on.
Anyways, I tried it on my own, but I got something different than you have. I'm not sure if my solution is correct:##P'(R) = V^2 (R+r)^{-2 }+ (RV^2)(-2)(R+r)^{-3} = 0##
if R = r:
##V^2 (r+r)^{-2} + (rV^2)(-2)(r+r)^{-3} = 0##
##(rV^2)(-2)(r+r)^{-3} = \frac{-V^2}{(r+r)^2}##
##(rV^2)(-2)(2r)^{-3} = \frac{-V^2}{(2r)^2}##
##\frac{(rV^2)}{(2r)^3} = \frac{V^2}{2(2r)^2}##
##rV{^2} = \frac{V^2(2r)^3}{2(2r)^2}##
##rV{^2} = \frac{V^2(2r)}{2}##
##rV{^2} = \frac{2V^2 rV^2}{2}##
##rV{^2} = V^2 rV^2##
##0 = \frac{V^2 rV^2}{rV^2}##
##0 = V^2##
##0 = V##
So technically, if R = r, the derivative is zero when V is zero. But is that enough to show that the maximum power is dissipated when R = r?
Also, thank you for the link to the LaTeX tutorial! :)
chocolatecake said:
P′(R)=V2(R+r)−2+(RV2)(−2)(R+r)−3=0P'(R) = V^2 (R+r)^{-2 }+ (RV^2)(-2)(R+r)^{-3} = 0
if R = r:
V2(r+r)−2+(rV2)(−2)(r+r)−3=0
I wouldn't set r=R so early. Just see if you can simplify the derivative down to the final form that I showed, and then see if you can solve for R in terms of r then...
I understand now how to find the derivative but I don't understand how to simplify to ##-R^3-R^2r+Rr^2+r^3 =0##
How did you get R^2r or Rr^2? I tried using the binomial theorem for (R+r)^2 and (R+r)^3 but that made everything even more confusing.
What I ended up with is basically this:
##\frac{V^2(R+r)+2(RV^2)}{2R^3+6R^2r+6Rr^2+2r^3}=0##
But this doesn't look right.
So I decided to pick random values for R and V instead:
R = 3
V = 4
##(3)(4^2)(-2)(3+r)^{-3}+(3+r)^{-2}(4^2)=0##
##48(-2)(3+r)^{-3}+(3+r)^{-2}(16)=0##
##\frac{-96}{(3+r)^3}+\frac{16}{(3+r)^2}=0##
##96=\frac{16(3+r)^3}{(3+r)^2}##
##96=16(3+r)##
##3=r##
Therefore, r = R
Is that correct?
chocolatecake said:
I understand now how to find the derivative but I don't understand how to simplify to −R3−R2r+Rr2+r3=0-R^3-R^2r+Rr^2+r^3 =0
[tex]\frac{-2RV^2}{(R+r)^3} + \frac{V^2}{(R+r)^2} = 0[/tex]
Divide both sides by V^2 to get rid of the voltage dependence (it is not needed), put both of the LHS terms over a common denominator, multiply both sides by that denominator to get rid of it, distribute terms, gather terms, and I get to:
I think it can be factored, but I haven't gotten that to work right away. I'll give it another shot. Can you work through simplifying the derivative and eliminating the voltage V now?
See if ##(r - R)(r + R)^2## fills the bill :smile:
Lordy, I was off in the weeds with 6 unknowns and 4 equations in the factoring... Thanks for the help!
An easier way is to make the denominator simpler by substituting S=R+r:
##\frac{P}{V^2}=\frac{S-r}{S^2}##
Differentiating wrt S, and multiplying by S4 to get rid of the denominator: ##S^2=2S(S-r)##.
Ok, that makes sense to me now. If I do it, it looks like this:
##\frac{-2R(-2)V^2}{(R+r)^3}+\frac{V^2}{(R+r)^2}=0##
divide by ##V^2## :
##\frac{4R}{(R+r)^3}+\frac{1}{(R+r)^2}=0##
common denominator:
##\frac{4R(R+r)^2}{(R+r)^5}+\frac{(R+r)^3}{(R+r)^5}=0##
multiply by common denominator:
##4R(R+r)^2+(R+r)^3=0##
but after that it looks different from what you have:
expand the terms:
##4R(R^2+Rr+Rr+r^2)+R^3+3R^2r+3Rr^2+r^3=0##
and I end up with:
##5R^3+11R^2r+7Rr^2+r^3=0##
Where did I go wrong? Where are the negative signs in your equation coming from?
PV2=S−rS2\frac{P}{V^2}=\frac{S-r}{S^2}
Differentiating wrt S, and multiplying by S4 to get rid of the denominator: S2=2S(S−r)S^2=2S(S-r).
But if I substitute R+r with S, then I have three variables. And I don't understand where the ##\frac{P}{V^2}## is coming from. If we have a P there, then there are four variables (S, V, P and R).
−2R(−2)V2(R+r)3+V2(R+r)2=0\frac{-2R(-2)V^2}{(R+r)^3}+\frac{V^2}{(R+r)^2}=0
Where did the extra -2 come from in the numerator of the first term?
Well, the numerator was ##-2RV^2##, so I rewrote it as ##-2R(-2)V^2##.
But I just realized that this was nonsense because it would only work if the numerator was ##-2(R+V^2)##.
I'll try it again, give me a few minutes.
Now I got it! :partytime:
##-2R(R^2+Rr+Rr+r^2)+R^3+3R^2r+3Rr^2+r^3=0##
##-2R^3-2R^2r+(-2R^2r)-2Rr^2+R^3+3R^2r+3Rr^2+r^3=0##
##-R^3-R^2r+Rr^2+r^3=0##
and then if I substitute R=r, I get the same as you did: ##-R^3-R^3+R^3+R^3=0##
Thank you!
But now I still have to find the absolute maximum, or is this sufficient to show that R = r at the max. dissipated power?
Given the help we got from @gneill in factoring, it looks like there is only one value of R that makes that equation equal to zero, right?
And to show that it maximizes power, you could either evaluate the 2nd derivative at that point to verify that it is negative, or you could plug R = 1.1r and R = 0.9r into the original power equation to show that you get less power delivered to R when it's slightly more or less than matching r.
Good job, and way to hang in there! :smile:
Great, I will try that!
Thank you for your help and your time! :smile:
And thank you to the others who helped as well of course! :smile:
I came up with a total of 5 solutions.
Though, R = r was the only one that made sense.
The others were kind of impractical.
No, S is instead of R, so still only two variables.
You started with ##P=\frac{RV^2}{(R+r)^2}##. I just divided through by V2 then replaced R by S-r everywhere.
In physical terms, I am keeping r fixed and varying the total resistance. The maximum P occurs when the sum, S, is 2r.
P=I2R=E2R/(r+R)2
∴dP/dR=E2[(r+R)2-2R(r+R)]/(r+R)4.
For dP/dR=0,
the numerator of the above equation should be 0, which gives r=R.
cnh1995 said:
P=I2R=E2R/(r+R)2
For dP/dR=0,
That looks like a nice reason to use the quotient rule for the differentiation in this case, I guess (I still dislike it in general). :smile:
But you still have to distribute and factor the numerator to be sure r=R is the only solution, don't you?
Yeah, the numerator beomes
r2+2rR+R2-2rR-2R2=0, which simplifies to
r2-R2=0.
So r=R is the only sensible solution.
cnh1995 said:
P=I2R=E2R/(r+R)2
But that's a different equation from the one in the problem, isn't it?
No, the equation for the power is the same as in the OP.
For finding dP/dR, the quotient rule is used.
