How Do You Find a Unit Vector Orthogonal to Two Given Vectors?
  • Thread starter Thread starter kwal0203
    Orthogonal Vector
12 replies · 3K views · last reply
kwal0203
Find a unit vector that is orthogonal to both [itex]u=(1,1,0)[/itex] and [itex]v=(-1,0,1)[/itex]
Any help appreciated thanks!
haruspex said:
What do you know about the direction of the cross product of two vectors?
Yeah, I see where you are going with that but I need to answer the question without using the cross product
Ok, so how about supposing the vector is (x, y, z) and obtaining some equations based on dot products?
I could try that, how do I do it?
[itex]u\cdot v=(1,1,0)\cdot (-1,0,1)=-1+0+0=-1[/itex]
[itex]u\cdot v=\left \| u \right \|\left \| v \right \|cos\theta[/itex]
the dot product represents the angle between the vectors, is that correct?
No, I meant take the dot product of (x, y, z) (a vector intended to be orthogonal to the two given vectors) with each of them.
let [itex]x=(x,y,z)[/itex]
[itex]x\cdot u=(x,y,z)\cdot (1,1,0)[/itex]
[itex]x+y=\left \| x \right \|\left \| u \right \|cos\theta=0[/itex]
[itex]x\cdot v=(x,y,z)\cdot (-1,0,1)[/itex]
[itex]z-x=\left \| x \right \|\left \| v \right \|cos\theta=0[/itex]
[itex]x+y=z-x[/itex]
[itex]y=z[/itex]
something like this?
I don't understand what u and v represent in there. looks like in the first line they represent (x,y,z) and (1,1,0), and in the second line (x,y,z) and (-1,0,1). But then you deduce an equation based on u and v representing the same in both cases??
If two vectors are orthogonal, what is their dot product?
Edit: It's late here ... and so to bed.
Whoops, I fixed up the code. Does it look better now?
The dot product of two orthogonal vectors is equal to zero.
It's confusing to have one symbol mean two different things, so I recommend that you don't use this notation. I'll use ##p=(x,y,z)##.
You should write this as
$$0 =p\cdot u=(x,y,z)\cdot (1,1,0) =x+y.$$ No need to mention the angle between the vectors. Also, you're confusing your readers when you put the zero at the end, instead of at the beginning next to ##p\cdot u## which is equal to 0 by definition of p. (Edit: OK, I see that the thing at the end is also obviously equal to zero because the angle between the vectors is ##\pi/2##, but I still prefer to put the zero at the beginning, where no thought is required). You also left out an equality sign.
Similarly,
$$0=p\cdot v =(x,y,z)\cdot (-1,0,1) =-x+z.$$
[itex]y=z[/itex]
Yes, something like that. But not that. First you threw away useful information from the equalities ##p\cdot u=0## and ##p\cdot v=0##, and then you incorrectly canceled x and -x from what you had left.
