How do you prove the force between two conductor plates is F=q^2/2eA?
The discussion centers on proving the force between two conductor plates as F=q^2/2eA, with e representing epsilon. It highlights the derivation of the electric field from one plate, where E=q/2eA is used, leading to the conclusion that the force formula is valid under the assumption of uniform charge distribution. Participants express confusion regarding the application of Gauss's Law and the role of charge distribution, particularly in cases involving dielectrics. There is a noted inconsistency in how electric fields are calculated for insulated versus conducting sheets, with superposition not being applied to conductors. Overall, the conversation emphasizes the complexities of electric field calculations and charge distribution in conductor systems.
brentd49
How does one prove that the force between two conductor plates is F=q^2/2eA, where e=epsilon.
If I use F=qE. Where the electric field is generated by one of the conducting plates: E=q/eA, then F=q^2/eA.
I think what the answer assumes is that the E-field is from a uniform plate (insulator): E=q/2eA. In that case, F=q^2/2eA, which is the correct answer. But how can you make that assumption when obviously two conductor plates will have all their charge on the surface facing the other plate?
^bump
I must have some concept wrong, because they use that equation again for the conductor when they are caculating the electric field inside a conductor with a dielectric, i.e. E=qf/2eA+qf/2eA-qi/2eA-qi/2ea (where qf=free charge on conducting plate, and qi=charge bound to dielectric).
I am a little unsure how they are coming up with that 1/2, because in my book they derived the Electric field using surface charge density (with Gauss' Law, of course), and the result is E=o/e (surface charge density/epsilon)--no 1/2. I suppose if you are dealing with charge and not charge density, then an excess charge 'q' will distribute q/2 on each surface.
So, I am now completely lost. Because I thought the influence of another charged plate would draw all of the 'q' to one surface, even with a dielectric.
I understand now, thanks. I think Halliday, Resnik could have done a better job, though.
Yeah, when I first studied EM, it was not so intuitively obvious to me, despite the fact that the textbooks and professors claimed it so.
Anyway, it comes down to the charge distribution and Gauss's law.
See if this helps.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gaulaw.html#c1
In the case, where there are equal and opposite charge densities, the contribution to the electric field must be equal, so that each charge distribution contributes
E = \frac{\sigma}{2\epsilon_o}, and the combined field is
E = \frac{\sigma}{\epsilon_o}
All textbooks seem to use the same example, and I think they could all do a better job.
I looked at the links, but I'm still having a little trouble..
(1) There seems to be an inconsistency when applying Gauss's Law. When they calculate the electric field between two insulated sheets they use superposition to find the net electric field. But for two conducting sheets, the derivation does not require superposition. In both cases the electric field is the same (E=q/eA), but if superposition was used for the conductor then E would be twice as large (two sheets), E=2q/eA. EDIT: This could be because they keep interchanging the charge density based on the situation--this isn't helping.
(2) Does a dielectric block the external electric field between two capacitor plates? Because the book solution for the electric field between a capacitor with a dielectric is: E=qf/2eA+qf/2eA-qi/2eA-qi/2ea (where qf=free charge on a conducting plate, and qi=charge bound to dielectric). The qf/2 implies the charge distribution is divided on the two halves of the conducting plate, whereas typically all the charge is on the surface facing the other plate.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
