How Do You Prove the Given Approximation Formula Involving e^{-t/τ}?
7 replies · 2K views
anhnha
Hi.
Please help me prove the approximation formula below given in my book. This is not homework question.
Thanks.
Mathematics news on Phys.org
You just neglect ##\tau_1## or ##\tau_2##, whatever is smaller. Note that a larger value will lead to a larger exponential as well (for positive t).
Thank you. However, that doesn't solve the problem. What need to be proved is different.
[tex]\frac{τ_1e^{-\frac{t}{τ_1}}-τ_2e^{-\frac{t}{τ_2}}}{τ_1-τ_2}=\frac{e^{-\frac{t}{τ_1}}-(τ_2/τ_1)e^{-\frac{t}{τ_2}}}{1-(τ_2/τ_1)}=e^{-\frac{t}{τ_1}}\left(\frac{1-(τ_2/τ_1)e^{-t(\frac{1}{τ_2}-\frac{1}{τ_1})}}{1-(τ_2/τ_1)}\right)=e^{-\frac{t}{τ_1}}\left(\frac{1-(τ_2/τ_1)e^{-t\frac{(τ_1-τ_2)}{τ_1τ_2}}}{1-(τ_2/τ_1)}\right)[/tex]
If τ1>>τ2, then [itex]e^{-t\frac{(τ_1-τ_2)}{τ_1τ_2}}<1[/itex].
From this, it follows that, in the numerator, [itex](τ_2/τ_1)e^{-t\frac{(τ_1-τ_2)}{τ_1τ_2}}<<1[/itex]
Also, in the denominator, [itex](τ_2/τ_1)<<1[/itex]
So the term in parenthesis approaches unity.
Chet
Why? It shows that the big [/size] is a correct approximation.
I guess the analysis I did in #4 did not work for the OP? (It was just a more fleshed-out version of what mfb was saying).
Chet
Thank you all.
I think you misread the question a bit. The expression on the right hand side of the equation is [tex]e^{-\frac{t}{τ}}[/tex] with [tex]τ = τ_1 + τ_2[/tex].
anhnha said:
Thank you all.
You're right. But that doesn't matter much. The same general procedure could be used for this.
Chet
